Propeller II: Drivers & Tools (please see post #1 before posting here) — Parallax Forums
Cluso99Cluso99 Posts: 18,069
edited 2013-03-28 18:53 in Propeller 2
Rules for this thread...
  1. This thread is currently intended for P2 Drivers and/or Tools that can be used in the development of P2 Programs on the DE0 & DE2 P2 emulations prior to the release of the P2.
    • What will happen after release of the P2 is not known at this time.
  2. Only 1 post per Driver or Tool which may/should include:
    • Description of the Driver or Tool.
    • Link to the thread(s) where discussion about this driver/tool is taking place
    • MUST INCLUDE: "Please use this link to the appropriate thread for any questions or discussions about this Driver/Tool."
    • Attached Driver or Tool and any demonstration code or instructions (optional but preferred)
Thanks for your co-operation.
    edited 2013-03-28 18:10
    -reserved-
    Sample format (you can use reply with quote and remove the quote parameters at the top and bottom, then fill in the blanks)
    DRIVER/TOOL:
    Driver-or-Tool-Name
    DESCRIPTION:
    1. xxx
    2. xxx
    DISCUSSION THREAD:
    Paste-link-here
    Insert-attachments-here
    DRIVER:
    SerialDebugger
    DESCRIPTION:
    1. LMM execution loop for LMM code
    2. Hub based LMM code for SerialDebugger
    3. This debugger currently has the following call options:
      • TX - send a long as character(s), lower byte first. ($00 from the top byte down are ignored)
      • ASCII - send TX character(s) where control/invisible characters $00..$1F and $7F..$FF will be output as "<xx>" where xx=hex.
      • HEX - send a long as HEX with using the number of digits specified (8..1). Optional modifiers are:
        • REVERSED - the long is sent lower byte first
        • SPACE - a space is added between hex character pairs
      • STRING - sends a string of TX characters and is terminated by a $00 (nul)
      • DUMP - sends 4 longs as a string of spaced hex characters followed by ASCII characters where control/invisible are sent as "."
        • Modifiers are COG and HUB where HUB is the default.
        • Lower byte is sent first (HEX REVERSED) as would be normal when dumping memory using byte mode.
      • RX - waits to receive a character. Half duplex is used, so any characters received when not waiting in this loop are ignored.
    4. Does all this from your program's cog:
      • Uses the same cog as the users program. The user calls the debugger to send/receive and at the end, the debugger returns to the users program.
      • Uses a small cog footprint
      • Uses minimal P2 resources
      • Uses hub to store the LMM debug code
      • Excellent for debugging P2 programs using the single cog DE0 emulator
      • LMM mode is a method where each instruction is copied from hub to cog to be executed in an LMM execution loop (devised by Bill Henning for the P1).
    DISCUSSION THREAD:
    http://forums.parallax.com/showthread.php/146688-LMM_SerialDebug-Simple-Serial-Tx-amp-Rx-for-debugging-single-cog-programs
    LMM_SerialDebugger_030.spin
