P2 Tips & Tricks — Parallax Forums
P2 Tips & Tricks
Cluso99Cluso99 Posts: 18,069
edited 2013-03-22 18:50 in Propeller 2
I thought I would start a new thread with Tips & Tricks of the Propeller II. Please post any tips or tricks you have found here (or links to threads).
    edited 2013-03-20 17:07
    SAVE & RESTORE Z & C FLAGS
    When using CALL & RET instructions, you can save and restore the Z & C flags using the same instruction - just use the WC and WC modifiers on the CALL/RET instructions. On the CALL, the cog return address is saved at the Destination in bits 8..0 and the Z & C (if WZ & WC are specified) in bits 10 & 9 respectively.
    It is that simple!!! Thanks Chip :)
                  call  #routine    wz,wc           ' call a subroutine and save the Z & C flags
    routine       ...
    routine_ret   ret               wz,wc           ' return and restore the Z & C flags
    Caution: Because the Z & C flags are stored in bits 10 & 9 of the destination, they in fact are bits 1 & 0 of the D field. Therefore, you cannot save the return address with flags into a CALL instruction as the D field would be corrupted. This works fine in a JMP or RET instruction because the D field is not otherwise used.
    This one is more of an interesting feature, but a trick nonetheless...
    There is a new instruction pair, SUBR and CMPR (R=reverse) which perform D=S-D
    Here is a trick to using CMPR (from Chip's P2 ROM Monitor)...
    'checking for visible characters in the ascii chart from $20..$7E (" ".."~")
                    cmp     x,#" "          wc      'visible chr?  set c if <" "
            if_nc   cmpr    x,#"~"          wc      'visible chr?  set c if >"~ "
            if_c    jmp     #:loop                    'not visible if c set
    Now the interesting part is that this instruction pair's opcode is also shared with SETINDx instructions. For a long time I remained convinced that there was an error in the decoding of these instructions despite Chip's assurance there was not. Of course I was wrong and here is why...
    The SETINDx instructions always have WZ, WC & WR as =0. The SUBR always has WR=1. No problems here.
    But, CMPR has WR=0 (i.e. NR). So how can this be shared with SETINDx?
    Then penny dropped. You cannot have a useful CMPR without either WZ and/or WC.
    So, SETINDx required WZ=WC=WR=0 and CMPR requires either WZ=1 and/or WC=1, and SUBR requires WR=1.
    Very smart decoding Chip ;)
    BTW: pnut does not enforce the setting of WZ or WC.
