P8X32A Quickstart board power supply without USB?
I had started a thread awhile back concerning learning about the Propeller.
I keep going back to the various threads, see some of the difficulties people are having and
I still feel the need to use a Prop on my currently in process platform project.
I'm convinced that the Propeller is the future.
Today, I went to my local Radio Shack store and looked at their Quickstart Board.
Cost was about $18 more than directly through Parallax, but it did include a cable.
I noticed that there is no power supply available without using the USB connection.
I have very basic needs, but my needs cannot be tied only to a USB cable.
What do people do to connect a Quickstart Board to a battery or other mobile power supply.
I realize this should have a simple solution, I just don't know what options are available.
I've been looking at this for a couple of months, and almost made a purchase, even at elevated cost, but I got over it.
Thanks for any suggestions,
Garyg
Garyg
You can also add a jumper to /USB POWER ENABLE so that you can also power the board using a USB power supply. Some addon boards include this as an optional jumper, but you can also do it easily yourself.
Here's some details and a picture.
http://www.instructables.com/id/How-to-build-the-QuickPlayer-Extreme/step8/Special-page-for-DIYers/
Jeff
Assuming you have a diode in the external power (Vin) lead, your power supply should provide a voltage greater than 4V and less than maybe 9V (depending on the amount of current drawn from the 3.3V regulator ... heat issues).
The P8X32A that is shown in the Instructables link is different from the one that Mike is talking about.
Also, The P8X32A that I was looking at in my local Radio Shack store appears to be the same one
that Jeff has the link to in the Instructables.
I'm thinking that the jist of this discussion so far is that there is really no straightforward way of using the P2X32A without the
USB cable connecting it to my computer.
My plan for now will be this:
Locate a drawing for the P8X32A from the Parallax website or elsewhere.
Discover the pinout of the USB connection and find out what is powering the P8x32A product.
Fabricate a battery and plug that will connect into the P8X32A.
Plug in the battery to the P8X32A and maybe Life Will Be Good.
I will definitely look at the QuickStart schematic for the details concerning Vin location.
I always look at the cost of building my small projects in that projects always cost about 10X what I'm expecting.
Thanks for your comments so far.
I may reconsider and keep sticking with my Basic Stamps.
But I will look into this further.
If it helps, the Quickstart sold by Propellerpowered comes with the ProtoLite board which can be powered both by USB (Power Enable Jumper) and by connection to screw terminals.
This may help you lower the costs of your projects a little bit more.
http://propellerpowered.us/index.php?route=product/product&path=25_61&product_id=52
Jeff
Jeff's method is if you want to plug a USB power supply (wall wart with USB mini-B on the end of the cable) of some sort into the USB port and power it that way.
Mike's method works if you want to plug the black wire from a battery pack into VSS and the red wire into VIN.
You can also solder a pair of male pins into the holes marked VSS/VIN just off the end of the header and then put a pair of female connectors on your battery pack.
If there is the potential for the voltage differences between your power source and the USB, then the diodes is a good idea.
Jeff and Mike both know what they are talking about.
Here's a picture that kind of shows what I'm talking about.
For a while after the QuickStart came out, I tried to collect links about the board and posted the links to this thread. I also added posts about some of my own QuickStart projects to the thread.
There are some additional photos in that thread that you might find helpful.
Jeff and I recently posted threads about using the QuickStart as the controller to an inexpensive robot.
Here's a picture of my version of CheapBot.
Besides the pair of male headers for the power connection, I also populate the four Vss and four Vdd positions on the right side of the board with female headers.
These added headers and the label, make the QuickStart much more user friendly IMO. The labels make a big difference when I'm adding a wire to a specific pin. It's much easier to read the label than trying to count holes.
If you send me a PM with your address, I'll send you a couple of these labels. Phil also made some labels that look really nice. He was giving away his labels for a while but I don't think he's still giving them away.
I've attached the file (in the QuickStart thread) for printing the labels in case you happen to have a Brother label maker (it needs to be one that can interface with the PC).
I hope you give the QuickStart another try before giving up on it. The Propeller make projects possible that are way beyond the possibilities of the Basic Stamp.
Where did you get them? I never heard of them coming stock with 9v battery connectors...
I have ordered a P8X32A.
It appears to be a good place to start learning how to use the Propeller.
All of your comments have answered my Propeller Beginner questions.
I'm guessing your battery is a Lithium Ion battery? While the "nominal" voltage is listed as 3.7V, a freshly charged Li-Ion cell can have a voltage of over 4.2V.
The Propeller's datasheets lists the supply voltage range as 2.7V to 3.6V. The "Absolute Maximum Rating" for Vdd is listed as 4.0V. I strongly suggest you stop using a Li-Ion cell to power the Propeller without a regulator.
You may be able to power the QuickStart with pins 39 and 40 of the main header with your battery. When the cell is freshly charged, it will be above the 4V limit. I'm not positive but I think voltages less than 4.0V will work, but the output from the 3.3V regulator will likely be lower than 3.3V.
I think using a Li-Ion cell to power the QuickStart from pins 39 and 40 is a much safer than powering the QuickStart with a Li-Ion cell directly to Vdd and Vss.
It is the Lithium-Ion, but will hardly ever get above, as I'm also using the on-board regulator as the limit on the charge voltage. The battery itself says a Maximum charge voltage of 4.2V, but I am charging it through the 17-33 regulator.. (barely trickle charge) just pulled the battery after charging through the regulator, and I'm reading only 3.31 absolute tops.
Jim
