Issues programming SX28 — Parallax Forums
thomasschubertthomasschubert Posts: 15
edited 2012-09-10 16:12 in General Discussion
Hi Its been a few years since I have used the SX28, Im having a few issues programming the device. Im using an SX Key Rev F, old programmer. Have a USB Blitz but cant find a cable :{When I try and read a device it comes up with comms errors, somtimes it makes through 50% somtimes 70% then just nothing "SX device not found".<BR><BR>I seem to remember this problem a few years ago on the 52 device. I dont have a clock source connected to the device.
  • wasswass Posts: 151
    edited 2012-09-10 16:06
    What OS are you running? Do you have the correct driver installed on your PC?
  • ZootZoot Posts: 2,227
    Check that your connections are really clean between the key and the SX. Whenever I've had "random" failures to connect, it's been dirty contacts.
