Bending a tube without the walls collapsing or pinching....
Beau SchwabeBeau Schwabe Posts: 6,321
edited August 2012 in Robotics Vote Up0Vote Down
Anyone have an idea how to bend a 1/4' diameter brass or copper tube into a "U' shape without collapsing the side walls and pinching the tube? .. The tube is only 6 inches long to begin with.
BTW) I have tried taping the ends and packing it with salt prior to bending it and that did not work... perhaps I need to pack the salt in it tighter.
-thanks
Beau Schwabe -- Submicron Forensic Engineer
www.Kit-Start.com - bschwabe@Kit-Start.com ෴෴ www.BScircuitDesigns.com - icbeau@bscircuitdesigns.com ෴෴
Seriously at this point in the game the ship has sailed and "I have no expectations" <- said someone we know
  • 13 Comments sorted by Date Added Votes
  • Ron CzapalaRon Czapala Posts: 2,404
    edited August 2012 Vote Up0Vote Down
    There are spring tube benders you can purchase
    Like these http://www.ridgid.com/Tools/Spring-Tube-Benders
    Home Depot sells some online.
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,579
    An auto parts store should carry bending springs in that size. You can also use a regular extension spring from the hardware store. Just cut the loops off the ends. I've done that before with steel brake line (with one flare removed), and it works adequately. It also helps to bend it around a makeshift mandrel, rather than doing it freehand.
    OTOH, if the tubing tube is flared on both ends, you'll have to use a tubing tube bender:
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • jivy43jivy43 Posts: 11
    Beau, Your success in bending your tube without wrinkles, or collapsing the walls depends on several factors. Wall thickness and center line radius (clr) of the bend are the major ones. The heavier the wall thickness, the smaller chance of wrinkling and collapsing. A rule of thumb for the clr of the bend is 4 times the dia (4:1) of the tube being bent. Also the use of a bending die can help. Many off the shelf tubing benders, for small dia tubes, are 3:1 so you could get a clr of .75" instead of 1". Most of these benders have bending dies to help prevent collapsing, etc.
    Jim
    JIM IVY KD0SWA
    I am never wrong, I thought I was once, but I was mistaken.
  • Dr_AculaDr_Acula Posts: 5,482
    What Ron said post #2. I was using one just yesterday bending lots of copper pipe for a solar hot water system.
    Answers: 1) A quadcopter. 2) Very high. 3) The internet. 4) A lot. 5) No.
  • Prophead100Prophead100 Posts: 192
    -thanks
    The spring should work although I have seen ice used to help keep the diameter constant during a bend
  • bee_manbee_man Posts: 109
    Instead of salt, tape the end, fill with water and dish soap, freeze, bend, thaw.
    Thats how they do musical instrument brass slides.
    Jim
    http://www.youtube.com/watch?v=kh7RrlazaRc
    Bee_man really came up with a rather unusual, but interesting approach. I've never tried to make my own trombone.
    Hwang Xian Shen, Puddleby-on-the-Marsh.
    All things considered, I can live and thrive without Microsoft products. LINUX is just fine.
  • idbruceidbruce Posts: 5,558
    Beau
    For brass tubing, use a brake line bender found at the auto parts store. However the key to bending brass tubing without kinking it is to anneal it first with propane or mapp gas. After you heat it up and let cool, you should be able to bend the U Shape without kinks.
    Bruce
    EDIT: This would probably also work for copper
    Novel Solutions - http://www.novelsolutionsonline.com/ - Machinery Design • - • Product Development
    "Necessity is the mother of invention." - Author unknown.
    Beau
    I thought perhaps I should add more information.
    While bending, ensure that the bending shoe is always firmly against the tube to prevent slippage, and additionally, place the tubing on a flat level surface and ensure that the excess tube is always flat against the work surface and that the bender is in firm contact with the tube.
    You can also do incremental bends to create a larger U shape. Intead of trying to make a U in one shot and relying upon the bender radius to give you the proper size, you could make several bends at 10, 15, 20, 30 degrees, etc...
  • W9GFOW9GFO Posts: 3,730
    Copper can be annealed by heating with a torch then quenched in water. Unlike ferrous metals.
    Here's a reference;
    http://steamshed.com/annealing%20process.html
