Cache problems
sylvie369sylvie369 Posts: 1,618
edited December 2011 in Accessories Vote Up0Vote Down
I have been working through MIke G's tutorial, and had gotten as far as making the LED turn on and off from a web page. It had been working fine, but this morning stopped working. After rechecking things, I thought to clear the browser cache, and that got it working again - exactly once. I can click once to turn the LED on, then click the off button and it turns off, and then nothing happens again until I clear the cache again. I've tried it several times, and this is now reliably how it works.
Obviously I'm not going to be able to work through the rest of the tutorial this way. Is there a way to get the browser to NOT cache the page, so it retrieves it fresh each time and the examples actually work? I'm using Firefox 3.6.24 currently, and ideally will be able to continue to do so.
  • 8 Comments sorted by Date Added Votes
  • LeonLeon Posts: 7,619
    edited December 2011 Vote Up0Vote Down
    I think you can tell FF not to cache a web site.
    Leon Heller
    G1HSM
  • Mike GMike G Posts: 2,702
    Please post the source code. Which section of the tutorial are you working on?
    Also, cache is controlled in the response object.
    Any fool can make something complicated. It takes a genius to make it simple. Woody Guthrie
  • sylvie369sylvie369 Posts: 1,618
    Here is the code I have been using. I'll double-check as soon as I've posted to make certain I'm still having this problem with this code.
    Later: Checked, and yes, with this code loaded, I can turn the LED on once, and off once, and then I need to clear my cache to do it again. Clearing the cache does reliably get it to work again - exactly once.
    The code is your program for blinking the LED, with a little additional code under the PRI methods (some in Dispatcher, and then two new methods below that). Other than that and of course the changes to the MAC, IP, Gateway, etc., it's just your stock code. I was attempting to set up a webpage by which I could turn on and off the p22 LED on one page, and on another, turn on and off p23. If you can see what I did wrong there, I'd appreciate advice on that as well - I expect to start a separate thread on that at some point.
    Just checked - I get exactly the same behavior with your stock code (HTTPServer with LED, with only the MAC, IP etc. changed).
    I'm at the GETing to the Server page of your tutorial. Again, I had that working just fine, reliably, but it no longer is (but see next paragraph).
    This is probably important:
    I set the time on the RTC, and I'll bet that's related to the problem. It had been working quite reliably before I did that. I've taken a look at the code in Response, but it's way over my head. My best guess is that before I set the RTC, the time reported was late enough that the page was constantly expired, and therefore reloaded each time, but once I set the clock, that was no longer true, and the page is not expired (and therefore loads from the cache). How'd I do?
    The PST output reports that everything is fine, and also reports the correct time from the RTC.
    Copyright (c) 2011 AgaveRobotics LLC.
    See end of file for terms of use.
    File....... HTTPServer.spin
    Author..... Mike Gebhard
    Company.... Agave Robotics LLC
    Email...... mailto:mike.gebhard@agaverobotics.com
    Started.... 11/01/2010
    Updated.... 07/16/2011
    About:
      HTTPServer is the designed for use with the Spinneret Web server manufactured by Parallax Inc.
    Usage:
      HTTPServer is the top level object.
      Required objects:
            • Parallax Serial Terminal.spin
            • W5100_Indirect_Driver.spin
            • S35390A_SD-MMC_FATEngineWrapper.spin
            • Request.spin
            • Response.spin
            • StringMethods.spin
            • S35390A_RTCEngine.spin
    Change Log:
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      MAX_PACKET_SIZE = $5C0 '1472   '$800 = 2048
      RxTx_BUFFER     = $800         '$600 = 1536
      TEMP_BUFFER     = $600         '$5B4 = 1460
      TCP_PROTOCOL    = %0001        '$300 = 768
      UDP_PROTOCOL    = %0010        '$200 = 512
      TCP_CONNECT     = $04          '$100 = 256
      DELAY           = $05
      MAX_TRIES       = $05
      #0, DONE, PUT, CD
    DAT
      mac                   byte    $00, $08, $DC, $16, $F1, $D1
      subnet                byte    255, 255 ,255, 0
      gateway               byte    192, 168, 1, 1
      ip                    byte    192, 168, 1, 120
      port                  word    5000
      remoteIp              byte    65, 98, 8, 151 {65.98.8.151}
      remotePort            word    80
      uport                 word    5050
      emailIp               byte    0, 0, 0, 0
      emailPort             word    25
      status                byte    $00, $00, $00, $00
      rxdata                byte    $0[RxTx_BUFFER]
      txdata                byte    $0[RxTx_BUFFER]
      udpdata               byte    $0[TEMP_BUFFER]
      fileErrorHandle       long    $0
      debug                 byte    $0
      lastFile              byte    $0[12], 0
      closedState           byte    %0000
      openState             byte    %0000
      listenState           byte    %0000
      establishedState      byte    %0000
      closingState          byte    %0000
      closeWaitState        byte    %0000
      lastEstblState        byte    %0000
      lastEstblStateDebug   byte    %0000
      udpListen             byte    %0000
      tcpMask               byte    %1111
      udpMask               byte    %1000
      fifoSocketDepth       byte    $0
      fifoSocket            long    $00_00_00_00
      debugSemId            byte    $00
      debugCounter          long    $00
      stringMethods         long    $00
      closingTimeout        long    $00, $00, $00, $00
      udpLen                long    $00
      time                  byte    "00/00/0000 00:00:00", 0
      httpDate              byte    "Wed, 01 Feb 2000 01:00:00 GMT", 0
      globalCache           byte    $1
      dynamicContentPtr     long    @txdata
    VAR
      long StackSpace[20]
    OBJ
      pst           : "Parallax Serial Terminal"
      Socket        : "W5100_Indirect_Driver"
      SDCard        : "S35390A_SD-MMC_FATEngineWrapper"
      Request       : "Request"
      Response      : "Response"
      str           : "StringMethods"
      rtc           : "S35390A_RTCEngine"
    PUB Initialize | id, size, st
      debug := 1
      SDCard.Start
      stringMethods := str.Start
      Request.Constructor(stringMethods)
      Response.Constructor(stringMethods, @txdata)
      pst.Start(115_200)
      pause(200)
      'Mount the SD card
      pst.str(string("Mount SD Card - "))
      SDCard.mount(fileErrorHandle)
      pst.str(string("OK",13))
      pst.str(string("Start RTC: "))
      rtc.RTCEngineStart(29, 28, -1)
      pause(200)
      pst.str(FillTime)
      'Start the W5100 driver
      if(Socket.Start)
        pst.str(string(13, "W5100 Driver Started", 13))
        pst.str(string(13, "Status Memory Lock ID    : "))
        pst.dec(Socket.GetLockId)
        pst.char(13)
      if(debugSemId := locknew) == -1
        pst.str(string("Error, no HTTP server locks available", 13))
      else
        pst.str(string("HTTP Server Lock ID      : "))
        pst.dec(debugSemId)
        pst.char(13)
      'Set the Socket addresses
      SetMac(@mac)
      SetGateway(@gateway)
      SetSubnet(@subnet)
      SetIP(@ip)
      ' Initialize TCP sockets (default setting; TCP, Port, remote ip and remote port)
      repeat id from 0 to 3
        InitializeSocket(id)
        Request.Release(id)
        pause(50)
      ' Set all TCP sockets to listen
      pst.char(13)
        Socket.Listen(id)
        pst.str(string("TCP Socket Listener ID   : "))
        pst.dec(id)
        pst.char(13)
        pause(50)
      pst.Str(string(13,"Started Socket Monitoring Service", 13))
      cognew(StatusMonitor, @StackSpace)
      pause(250)
      pst.Str(string(13, "Initial Socket States",13))
      StackDump
      pst.Str(string(13, "Initial Socket Queue",13))
      QueueDump
      pst.str(string(13,"//////////////////////////////////////////////////////////////",13))
      Main
    PUB Main | packetSize, id, i, reset, j, temp
      ''HTTP Service
      repeat
        repeat until fifoSocket == 0
          bytefill(@rxdata, 0, RxTx_BUFFER)
          if(debug)
            pst.str(string(13, "----- Start of Request----------------------------",13))
            pause(DELAY)
          else
            pause(DELAY)
          ' Pop the next socket handle
          id := DequeueSocket
          if(id < 0)
            next
          if(debug)
            pst.str(string(13,"ID: "))
            pst.dec(id)
            pst.str(string(13, "Request Count     : "))
            pst.dec(debugCounter)
            pst.char(13)
          packetSize := Socket.rxTCP(id, @rxdata)
          reset := false
          if ((packetSize < 12) AND (strsize(@rxdata) < 12))
            repeat i from 0 to MAX_TRIES
               'pst.str(string(13,"* Retry *"))
              'Wait for a few moments and try again
              waitcnt((clkfreq/500) + cnt)
              if(packetSize > 12)
                quit
              if(i == MAX_TRIES)
                'Clean up resource request
                Request.Release(id)
                Socket.Disconnect(id)
                reset := true
                if(debug)
                  StackDump
                  pst.char(13)
                  QueueDump
                  pst.str(string(13,"* Timeout *",13))
          if(reset)
            next
          Request.InitializeRequest(id, @rxdata)
          if(debug)
            pst.char(13)
            HeaderLine1(id)
          else
            pause(DELAY)
          ' Process router
          Dispatcher(id)
          'Clean up request resource
          Request.Release(id)
          ' This starts the close process -> 0x00
          ' use close to force a close
          bytefill(@txdata, 0, RxTx_BUFFER)
          debugCounter++
      GotoMain
    PRI GotoMain
      Main
    PRI Dispatcher(id)
    ''do some processing before sending the response
      if(strcomp(Request.GetName(id), string("led")))
            Led(id)
      else
      if(strcomp(Request.GetName(id), string("ext")))
            pst.str(String("Reading ext file"))
            ExtPin(id)
      StaticFileHandler(id)
      return
    PRI Led(id) | qstr
          '' Get the query string value
          qstr :=  Request.Get(id, string("led"))
          if (strcomp( string("on"), qstr ))
            LedStatus(1)
          else
            LedStatus(0)
          return
    PRI ExtPin(id) | qstr
          qstr := Request.Get(id, string("ext"))
            ExtPinStatus(1)
          else
            ExtPinStatus(0)
          return
    PRI LedStatus(state)
          dira[23]~~
          outa[23] := state
          return
    PRI ExtPinStatus(state)
          dira[22]~~
          outa[22] := state
          return
    PRI StaticFileHandler(id) | fileSize, i, headerLen, temp, j
      ''Serve up static files from the SDCard
      'pst.str(string(13,"Static File Handler",13))
      SDCard.changeDirectory(@approot)
      pst.char(13)
      'Make sure the directory exists
      ifnot(ChangeDirectory(id))
        'send 404 error
        WriteError(id)
        return
      ' Make sure the file exists
      ifnot(FileExists(Request.GetFileName(id)))
        'send 404 error
        WriteError(id)
        return
      ' Open the file for reading
      SDCard.openFile(Request.GetFileName(id), "r")
      fileSize := SDCard.getFileSize
      'WriteResponseHeader(id)
      'BuildHeader(extension, statusCode, expirer)
      headerLen := Response.BuildHeader(Request.GetExtension(id), 200, globalCache)
      Socket.txTCP(id, @txdata, headerLen)
      if fileSize < MAX_PACKET_SIZE
        ' send the file in one packet
        SDCard.readFromFile(@txdata, fileSize)
        Socket.txTCP(id, @txdata, fileSize)
      else
        ' send the file in a bunch of packets
        repeat
          SDCard.readFromFile(@txdata, MAX_PACKET_SIZE)
          Socket.txTCP(id, @txdata, MAX_PACKET_SIZE)
          fileSize -= MAX_PACKET_SIZE
          ' once the remaining fileSize is less then the max packet size, just send that remaining bit and quit the loop
          if fileSize < MAX_PACKET_SIZE and fileSize > 0
            quit
          ' Bailout
          if(i++ > 1_000_000)
            WriteError(id)
            quit
      SDCard.closeFile
      return
    PRI WriteError(id) | headerOffset
      '' Simple 404 error
      pst.str(string(13, "Write 404 Error",13 ))
      headerOffset := Response.BuildHeader(Request.GetExtension(id), 404, false)
      Socket.txTCP(id, @txdata, headerOffset)
      return
    '' Write data to a buffer
    PRI PushDynamicContent(content)
      ' Write the content to memory
      ' and update the pointer
      bytemove(dynamicContentPtr, content, strsize(content))
      dynamicContentPtr := dynamicContentPtr + strsize(content)
      return
    '' directory and file handlers
    PRI ChangeDirectory(id) | i, found
      'Handle directory structure for this Request
      if(Request.GetDepth(id) > 1)
        repeat i from 0 to Request.GetDepth(id)-2
          'Return if the directory is not found
          ifnot(FileExists(Request.GetPathNode(id, i)))
            return false
          found := SDCard.changeDirectory(Request.GetPathNode(id, i))
      return true
    PRI FileExists(fileToCompare) | filenamePtr
    'Start file find at the top of the list
      SDCard.startFindFile
      'Verify that the file exists
      repeat while filenamePtr <> 0
        filenamePtr := SDCard.nextFile
        if(str.MatchPattern(filenamePtr, fileToCompare, 0, false ) == 0 )
          return true
      return false
    '' Time Methods and Formats
    PRI GetTime(id) | ptr, headerOffset
      ptr := @udpdata
      FillHttpDate
      bytemove(ptr, string("<p>"),3)
      ptr += 3
      bytemove(ptr, @httpDate, strsize(@httpDate))
      ptr += strsize(@httpDate)
      bytemove(ptr, string("</p>"),4)
      ptr += 3
      headerOffset := Response.BuildHeader(Request.GetExtension(id), 200, false)
      StringSend(id, @udpdata)
      bytefill(@udpdata, 0, TEMP_BUFFER)
      return
    PRI FillTime | ptr, num
     'ToString(integerToConvert, destinationPointer)
     '00/00/0000 00:00:00
      ptr := @time
      rtc.readTime
      FillTimeHelper(rtc.clockMonth, ptr)
      ptr += 3
      FillTimeHelper(rtc.clockDate, ptr)
      ptr += 3
      FillTimeHelper(rtc.clockYear, ptr)
      ptr += 5
      FillTimeHelper(rtc.clockHour , ptr)
      ptr += 3
      FillTimeHelper(rtc.clockMinute , ptr)
      ptr += 3
      FillTimeHelper(rtc.clockSecond, ptr)
      return @time
    PRI FillHttpDate | ptr, num, temp
     'Wed, 01 Feb 2000 01:00:00 GMT
      ptr := @httpDate
      rtc.readTime
      temp := rtc.getDayString
      bytemove(ptr, temp, strsize(temp))
      ptr += strsize(temp) + 2
      ptr += 3
      temp := rtc.getMonthString
      ptr += strsize(temp) + 1
      ptr += 5
      ptr += 3
      ptr += 3
      return @httpDate
    PRI FillTimeHelper(number, ptr) | offset
      offset := 0
      if(number < 10)
        offset := 1
      str.ToString(@number, @tempNum)
      bytemove(ptr+offset, @tempNum, strsize(@tempNum))
    '' SDCard Logger
    PRI AppendLog(logToAppend)
      '' logToAppend:  Pointer to a string of test we'd like to log
      if(FileExists(@logfile))
        SDCard.openFile(@logfile, "A")
      else
        SDCard.newFile(@logfile)
      SDCard.writeData(string(13,10,"----- Start "),14)
      SDCard.writeData(FillTime, 19)
      SDCard.writeData(string(" -----"),6)
      SDCard.writeData(@crlf_crlf, 2)
      SDCard.writeData(logToAppend, strsize(logToAppend))
      SDCard.writeData(string("----- End "),10)
      SDCard.closeFile
    '' Memory Management
    PRI Set(DestAddress, SrcAddress, Count)
      bytemove(DestAddress, SrcAddress, Count)
      bytefill(DestAddress+Count, $0, 1)
    '' Socekt helpers
    PRI GetTcpSocketMask(id)
      return id & tcpMask
    PRI DecodeId(value) | tmp
        if(%0001 & value)
          return 0
        if(%0010 & value)
          return 1
        if(%0100 & value)
          return 2
        if(%1000 & value)
          return 3
      return -1
    PRI QueueSocket(id) | tmp
      if(fifoSocketDepth > 4)
        return false
      tmp := |< id
      'Unique check
      ifnot(IsUnique(tmp))
        return false
      tmp <<= (fifoSocketDepth++) * 8
      fifoSocket |= tmp
      return true
    PRI IsUnique(encodedId) | tmp
      tmp := encodedId & $0F
      repeat 4
        if(encodedId & fifoSocket)
          return false
        encodedId <<= 8
      return true
    PRI DequeueSocket | tmp
      if(fifoSocketDepth == 0)
        return -2
      repeat until not lockset(debugSemId)
      tmp := fifoSocket & $0F
      fifoSocket >>= 8
      fifoSocketDepth--
      lockclr(debugSemId)
      return DecodeId(tmp)
    PRI ResetSocket(id)
      Socket.Close(id)
    PRI IsolateTcpSocketById(id) | tmp
      tmp := |< id
      tcpMask &= tmp
    PRI SetTcpSocketMaskById(id, state) | tmp
    '' The tcpMask contains the socket the the StatusMonitor monitors
      tmp := |< id
      if(state == 1)
        tcpMask |= tmp
      else
        tmp := !tmp
        tcpMask &= tmp
    '' W5100 Helper methods
    PRI GetCommandRegisterAddress(id)
      return Socket#_S0_CR + (id * $0100)
    PRI GetStatusRegisterAddress(id)
      return Socket#_S0_SR + (id * $0100)
    PRI SetMac(_firstOctet)
      Socket.WriteMACaddress(true, _firstOctet)
      return
    PRI SetGateway(_firstOctet)
      Socket.WriteGatewayAddress(true, _firstOctet)
      return
    PRI SetSubnet(_firstOctet)
      Socket.WriteSubnetMask(true, _firstOctet)
      return
    PRI SetIP(_firstOctet)
      Socket.WriteIPAddress(true, _firstOctet)
      return
    PRI StringSend(id, _dataPtr)
      Socket.txTCP(id, _dataPtr, strsize(_dataPtr))
      return
    PRI SendChar(id, _dataPtr)
      Socket.txTCP(id, _dataPtr, 1)
      return
    PRI SendChars(id, _dataPtr, _length)
      Socket.txTCP(id, _dataPtr, _length)
      return
    PRI InitializeSocket(id)
      Socket.Initialize(id, TCP_PROTOCOL, port, remotePort, @remoteIp)
      return
    PRI InitializeSocketForEmail(id)
      Socket.Initialize(id, TCP_PROTOCOL, port, emailPort, @emailIp)
      return
    PRI InitializeUPDSocket(id)
      Socket.Initialize(id, UDP_PROTOCOL, uport, remotePort, @remoteIp)
      return
    '' Debug/Display Methods
    PRI QueueDump
      '' Display socket IDs in the queue
      '' ie 00000401 -> socket Zero is next to pop off
      pst.str(string("FIFO["))
      pst.dec(fifoSocketDepth)
      pst.str(string("] "))
      pst.hex(fifoSocket, 8)
    PRI StackDump | clsd, open, lstn, estb, clwt, clng, id, ulst
      '' This method is purely for debugging
      '' It displays the status of all socket registers
      clsd := closedState
      open := openState
      lstn := listenState
      estb := establishedState
      clwt := closeWaitState
      clng := closingState
      ulst := udpListen
      lockclr(debugSemId)
      pst.char(13)
      repeat id from 3 to 0
        pst.dec(id)
        pst.str(string("-"))
        pst.hex(status[id], 2)
        pst.str(string(" "))
        pause(1)
      pst.str(string(13,"clsd open lstn estb clwt clng udps", 13))
      pst.bin(clsd, 4)
      pst.bin(open, 4)
      pst.bin(lstn, 4)
      pst.bin(estb, 4)
      pst.bin(clwt, 4)
      pst.bin(clng, 4)
      pst.bin(ulst, 4)
      pst.char(13)
    PRI HeaderLine1(id) | i
      pst.str(Request.GetMethod(id))
      pst.char($20)
      i := 0
      repeat Request.GetDepth(id)
        pst.char($2F)
        pst.str(Request.GetPathNode(id, i++))
    PRI Pause(Duration)
      waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)
      return
    PRI StatusMonitor | id, tmp, value
    '' StatusMonitor is the heartbeat of the project
    '' Here we monitor the state of the Wiznet 5100's 4 sockets
      repeat
        Socket.GetStatus32(@status[0])
        ' Encode status register states
        closedState := openState := listenState := establishedState := {
         } closeWaitState := closingState := 0
          case(status[id])
            $00: closedState               |= |< id
                 closedState               &= tcpMask
            $13: openState                 |= |< id
                 openState                 &= tcpMask
            $14: listenState               |= |< id
                 listenState               &= tcpMask
            $17: establishedState          |= |< id
                 establishedState          &= tcpMask
            $18,$1A,$1B: closingState      |= |< id
                         closingState      &= tcpMask
            $1C: closeWaitState            |= |< id
                 closeWaitState            &= tcpMask
            $1D: closingState              |= |< id
            $22: udpListen                 |= |< id
                 udpListen                 &= udpMask
        if(lastEstblState <> establishedState)
          value := establishedState
          repeat while value > 0
            tmp := DecodeId(value)
            if(tmp > -1)
              QueueSocket(tmp)
              tmp := |< tmp
              tmp := !tmp
              value &= tmp
          lastEstblState := establishedState
        lockclr(debugSemId)
        ' Initialize a closed socket
        if(closedState > 0)
          id := DecodeId(closedState)
          if(id > -1)
            InitializeSocket(id & tcpMask)
        'Start a listener on an initialized/open socket
        if(openState > 0)
          id := DecodeId(openState)
          if(id > -1)
            Socket.Listen(id & tcpMask)
        ' Close the socket if the status is close/wait
        ' response processor should close the socket with disconnect
        ' there could be a timeout so we have a forced close.
        ' TODO: CCheck for a port that gets stuck in a closing state
        'if(closeWaitState > 0)
          'id := DecodeId(closeWaitState)
          'if(id > -1)
            'Socket.Close(id & tcpMask)
        'pause(100)
    return
    DAT
      approot               byte    "\", 0
      defaultpage           byte    "index.htm", 0
      logfile               byte    "log.txt", 0
      'binFile               byte    "filename.bin", 0
      FS                    byte    "/", 0
      fn                    byte    "filename=", 0
      doublequote           byte    $22, 0
      crlf                  byte    13, 10, 0
      crlf_crlf             byte    13, 10, 13, 10, 0
      uploadfile            byte    $0[12], 0
      uploadfolder          byte    "uploads", 0
      tempNum               byte    "0000",0
      multipart             byte    "Content-Type: multipart/form-data; boundary=",0
      boundary              byte    $2D, $2D
      boundary1             byte    $0[64]
      'loadme                file    "TogglePin0.binary"
    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474;                                                   TERMS OF USE: MIT License                                                  &#9474;
    &#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
    &#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    &#9474;
    &#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    &#9474;
    &#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software&#9474;
    &#9474;is furnished to do so, subject to the following conditions:        &#9474;
    &#9474;        &#9474;
    &#9474;The above copyright notice and this permission notice shall be included in all copies or substantial ions of the Software.&#9474;
    &#9474;        &#9474;
    &#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          &#9474;
    &#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         &#9474;
    &#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   &#9474;
    &#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    Oh, and re. telling FF not to cache a website, I can find the place where you can see a list of sites you've told it not to cache, but I can't find a way to tell it not to cache one. I imagine that the solution might be to put some kind of "NO CACHE" statement into the HTML of my page, but I don't want to do that until I've heard from someone who knows what he/she is doing.
    Paul
    Paul, please post the HTML too.
    Oops - here you go.
    index:
    <html>
    <head>
    <title>Hello World</title>
    </head>
    <body>
    <div style="width:600px;margin:auto;">
      <h1 style="text-align:center;color:blue;">Hello World!</h1>
      <div style="text-align:center;"><a href="index.htm">Hello World</a> | <a href="led.htm">LED</a></div>
      <div style="text-align:center;"><a href="ext.htm">Ext. Pin</a>
    </div>
    </body>
    </html>
    led:
    <html>
    <head>
    <title>GETing to the Server</title>
    </head>
    <body>
      <h1 style="text-align:center;color:blue;">LED</h1>
      <p><a href="led.htm?led=on">LED On</a> :: <a href="led.htm?led=off">LED Off</a></p>
      <p>LED: <span id="placeholder"></span></p>
    </div>
    </body>
    </html>
    ext:
    <html>
    <head>
    </head>
    <body>
      <h1 style="text-align:center;color:blue;">Ext Pin</h1>
      <div style="text-align:center;"><a href="ext.htm">Ext Pin</a>
      <p><a href="ext.htm?led=on">Ext. Pin On</a> :: <a href="ext.htm?led=off">Ext. Pin Off</a></p>
      <p>Ext: <span id="placeholder"></span></p>
    </div>
    </body>
    Paul
    sylvie369, you are right it is a cache issue. Set the globalCache variable in the DAT section to zero.
    globalCache           byte    $0
    Sorry, about that... there are a few things in the code base that are not explained in the tutorial.
    Updated httpserv.spin in the Google repository.
    Mike, thanks for your tutorial and the quick, individualized responses here. I'd have never been able to get any of this stuff going myself, and it's really stuff that I should know something about.
    I'll give this a shot, and get back here ASAP with how it goes.
    (two minutes later)
    Works great. Thanks. I'm sure I'll be back here with other questions. Thanks again for making this understandable.
    (Later)
    There does seem to be a little glitch still. Sometimes a page won't load until I click the reload button on the browser. When the page doesn't load, reload reliably brings it up, and everything works. It seems to happen with each of the three pages I have. They often load just fine the first time, but also often need that reload.
