XBee API Code for BS2
StephenMooreStephenMoore Posts: 188
edited November 2011 in Accessories Vote Up0Vote Down
I am interested in any API code that has been written for the Stamp. I have written my own API comm program and would appreciate comments!
It will talk to any Xbee connected to a serial terminal on a PC that is talking in API mode (subset of full API definition) and I have a C source code terminal program if any body is interested.
I am sure there are lot's better ways to do this and I would like to improve my programs.
' {$STAMP BS2px, XbeeTX.bpx, XbeeRX.bpx}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' This program is a Stamp terminal for a Xbee ZB radio with SIP adapter
' written by S.G. Moore  6/5/2011
'----------------------- XBee definitions ------------------------- 20011-05-27
' -----[ XBee I/O Definitions ]-------------------------------------------------
XBeeRX   PIN 0
XBeeTX   PIN 1
XBeeRTS  PIN 2
' -----[ Xbee Constants ]-------------------------------------------------------
DemoAPI CON   $0
TxAPI   CON   $1
RxAPI   CON   $2
argBuff CON   120
TxOK    CON   $1
RxOK    CON   $2
NoRx    CON   $3
TxBad   CON   $4
RxBad   CON   $5
Baud    CON  396         ' 9600, 8, N
' -----[ Xbee Variables ]-------------------------------------------------------
char            VAR     Byte
idx             VAR     Byte
' -----[ Initialization ]--------------------------------------------------
CONFIGPIN DIRECTION, %0000000000000110
HIGH XbeeTX
GET argBuff, char
SELECT char
  CASE TxOK
     GOTO transmitComplete
  CASE RxOK
     GOTO receiveComplete
  CASE NoRx
     DEBUG "."
     RUN RxAPI
  CASE TxBad
     DEBUG CR, "Bad TX.", CR
  CASE RxBad
      DEBUG CR, "Bad RX.", CR
ENDSELECT
' -----[ Program Code ]----------------------------------------------------
Main:
DO
DEBUG "Input string.", CR
char = 0
idx = 0
DO WHILE char <> $0D
DEBUGIN char
PUT idx, char
idx = idx + 1
LOOP
PUT (idx-1), 0
RUN TxAPI
transmitComplete:
RUN RxAPI
receiveComplete:
DEBUG CR, "Received string: "
idx = 0
GET idx, char
IF char = "T" THEN transmitComplete
DO WHILE char <> 0
DEBUG char
idx = idx + 1
GET idx, char
LOOP
DEBUG CR
LOOP
END
'XbeeTx.bpx
' {$STAMP BS2px}
' {$PBASIC 2.5}
PIR1       PIN 0
PIR2       PIN 1
XBeeRX     PIN 2
XBeeTX     PIN 3
' -----------------[ Program Messaging Constants ]-------------------------------------
myApp      CON   $0        ' These values are slot ID's
TxAPI      CON   $1
RxAPI      CON   $2
argBuff    CON   120       ' Scratch Pad RAM for passing Xbee messages
notInit    CON   $0
TxOK       CON   $1          ' These values are passed through argBuff
RxOK       CON   $2
NoRx       CON   $3
TxBad      CON   $4
RxBad      CON   $5
chkTX      CON   $6
initDone   CON   $7
'------------------------[ Xbee TX API Header definition ]----------------------
'TX Data start, lenMSB, lenLSB, type, id, addr7, addr6, addr5, addr4, addr3, addr2, addr1, addr0, net1, net0, radius, options
' note: this address is for my Xstick on my PC, change if necessary
TX DATA  $7E, $00, $00, $10, $01, $00, $13, $A2, $00, $40, $66, $C4, $F9, $FF, $FE, $00, $00
idx     VAR   Byte
char    VAR   Byte
mlen    VAR   Byte
csum    VAR   Byte
msgAddr VAR   Word
'============================== Message Definitions ===========================
msg1      DATA    "Hello.",0
msg2      DATA    "Zone 1 detect.",0
msg3      DATA    "Zone 1 is clear.",0
' ------------------------------[ Program Code ]----------------------------
main:
GET argBuff, char
SELECT char
CASE 0                  ' argBuff is set to 0 if myApp has assembled it's own message
GOTO messageSetup
CASE 1                  ' otherwise a pre-recorded message is selected
msgAddr = msg1
CASE 2
msgAddr = msg2
CASE 3
msgAddr = msg3
ENDSELECT
'-------------------------------[ Message Setup ] ---------------------------
idx = 0                    ' selects a pre-recorded message from EEPROm
DO WHILE char <> 0
READ msgAddr + idx, char
PUT idx, char
idx = idx + 1
LOOP
messageSetup:
FOR idx = 0 TO 16             ' assemble API TX packet starting at scratchpad RAM address 50
READ (TX + idx), char         ' read message header from EEPROM
PUT (50+idx), char            ' store Xbee API message starting at RAM 50
NEXT
mlen = 0
GET mlen, char             ' get first character of message string
DO WHILE char <> 0
PUT (67 + mlen), char      ' move the message to the TxAPI buffer
mlen = mlen + 1            ' count message length in characters
GET mlen, char             ' get next character of message sring
LOOP
PUT 52, (mlen + 14)
csum = $00
FOR idx = 53 TO (66 + mlen)     ' compute check sum  (between LSB message length and CSUM)
GET idx, char
csum = csum + char              ' checksum = $FF - sum(between LSB message length and CSUM)
NEXT
csum = $FF - csum
PUT (67 + mlen), csum
FOR idx = 50 TO (67 + mlen)
GET idx, char
SEROUT XbeeTX, Baud, [char]   ' transmit the message to the Xbee UART
NEXT
PUT argBuff, ChkTX
RUN RxAPI
END
'XbeeRx.bpx
' {$STAMP BS2px}
' {$PBASIC 2.5}
PIR1       PIN 0
PIR2       PIN 1
XBeeRX     PIN 2
XBeeTX     PIN 3
TxAPI      CON   $1
RxAPI      CON   $2
notInit    CON   $0
RxOK       CON   $2
NoRx       CON   $3
TxBad      CON   $4
RxBad      CON   $5
chkTX      CON   $6
initDone   CON   $7
idx        VAR   Byte
char       VAR   Byte
start      VAR   Byte
lenMSB     VAR   Byte
lenLSB     VAR   Byte
type       VAR   Byte
id         VAR   Byte
add7       VAR   Byte
add6       VAR   Byte
add5       VAR   Byte
add4       VAR   Byte
add3       VAR   Byte
add2       VAR   Byte
add1       VAR   Byte
add0       VAR   Byte
net1       VAR   Byte
net0       VAR   Byte
retry      VAR   Byte
TXstat     VAR   Byte
disc       VAR   Byte
option     VAR   Byte
csum       VAR   Byte
calc       VAR   Byte
main:
GET argBuff, char
IF char = ChkTX THEN TXstatus
' read a message of Frame Type $90
SERIN XbeeRX, Baud, 1000, noMessage, [start, lenMSB,lenLSB, type, add7,add6, add5, add4, add3, add2, add1,add0, net1, net0, option]
SERIN XbeeRX, Baud, [SPSTR lenLSB-12, csum]
PUT (lenLSB - 12), 0
'  DEBUG CR, "Message start: ", HEX2 start, CR
'  DEBUG "Message size MSB: ", HEX2 lenMSB, CR
'  DEBUG "Message size LSB: ", HEX2 lenLSB, CR
'  DEBUG "Frame type: ", HEX2 type, CR
'  DEBUG "Source 64bit ID: ", HEX2 add7, HEX2 add6, HEX2 add5, HEX2 add4, " ", HEX2 add3, HEX2 add2, HEX2 add1, HEX2 add0, CR
'  DEBUG "Source net ID: ",  HEX2 net1, " ", HEX2 net0, CR
'  DEBUG "Packet option: ",  HEX2 option, CR
' verify checksum on incoming message
calc = type+add7+add6+add5+add4+add3+add2+add1+add0+net1+net0+option
idx = 0
DO
GET idx, char
calc = calc + char
idx = idx + 1
LOOP WHILE char <> 0
calc = $FF - calc
IF calc = csum THEN
PUT argBuff, RxOK                      ' return to slot 0 with RxOK success code
ELSE
DEBUG CR, "Check sum error.", CR
PUT argBuff, RxBad
ENDIF
RUN myApp
TXstatus:
' read a message of Frame Type $8B
SERIN XbeeRX, Baud, [start, lenMSB, lenLSB, type,id, net1, net0, retry, TXstat, disc, csum]
  IF TXstat <> $00  THEN
  DEBUG "Transmission error code: ", TXstat, CR
  PUT argBuff, TxBad
  ELSE
'  DEBUG "Transmission OK.", CR
  PUT argBuff, TxOK
  ENDIF
RUN myApp
noMessage:
PUT argBuff, NoRx                      ' signal program running in slot 0 that RX timeout occurred
RUN myApp
END
  • 6 Comments sorted by Date Added Votes
  • $WMc%$WMc% Posts: 1,879
    edited November 2011 Vote Up0Vote Down
    S.Moore...
    Your code is pretty slick....CRC to boot.
    I would like to see your C pc interface.
    I'm working with the XBee-WiFi units(XB24-WF) now.They are a little harder to use than the RovingNetworks RN-171/RN-174 but they seem to be more popular.
    Great work on the BS2 code
    __Walt McDonald__
    The Truth is out there
    It's not rocket-surgery
    I see why we don't have any water,All of the pipes are full of wires!
    E=WMc2
    Now with WiFi
    Not in the Spin Bunch
    import RPi.GPIO as GPIO
    ABB M202 certified
    ABB M211 certified
  • Ron CzapalaRon Czapala Posts: 2,400
    Here is some API code I did in March 2010 - I know it worked but I would need to study it again to make use of it :smile:
    Transmit
    ' {$STAMP BS2p}
    ' {$PBASIC 2.5}
    #SELECT $STAMP                          ' Select Baud constants
      #CASE BS2, BS2E, BS2PE
        T1200       CON     813
        T2400       CON     396
        T4800       CON     188
        T9600       CON     84
        T19K2       CON     32
      #CASE BS2SX, BS2P
        T1200       CON     2063
        T2400       CON     1021
        T4800       CON     500
        T9600       CON     240
        T19K2       CON     110
      #CASE BS2PX
        T1200       CON     3313
        T2400       CON     1646
        T4800       CON     813
        T9600       CON     396
        T19K2       CON     188
    #ENDSELECT
    Inverted        CON     $4000           'Value for inverted serial format
    Baud            CON     T9600      '+ Inverted 8,N,1 inverted
      XBFlow1   CON $11   'flow control character
      XBFlow2   CON $13   'flow control character
      XBEsc     CON $7D   'Escape control character
      XBDelim   CON $7E   'API start delimiter
      XBModemSt CON $8A   'Modem Status
      XBATcmd   CON $08   'AT command
      XBQueParm CON $09   'Queue parameter value
      XBResp    CON $88   'AT command response
      XBRemReq  CON $17   'Remote AT command request
      XBRemResp CON $97   'AT remote command response
      XBTx64    CON $00   'Request: 64-bit address
      XBTx16    CON $01   'Request: 16-bit address
      XBTxStat  CON $89   'Transmuit Status
      XBRx64    CON $80   'Rx Packet: 64-bit address
      XBRx16    CON $81   'Rx Packet: 16-bit address
      XBOptions CON $04   'Send packet with Broadcast Pan ID
      RX  PIN 0  ' XBee Receive Pin
      TX  PIN 2  ' Xbee Transmit Pin
      RTS PIN 6  ' RTS flow control pin
      XBFrame    VAR Byte  'frame number
      XBDestMSB  VAR Byte  'Dest XBee address
      XBDestLSB  VAR Byte  'Dest XBee address
      XBResult   VAR Byte
    ' checksum calculation:  add all bytes keeping only the lowest 8 bits of the result
    ' AND subtract from 0xFF (exclude frame delimiters AND length)
      XBCheckSum VAR Byte
      XBTxID   VAR Byte  'Set to XBRx16 or XBRx64
      XBData   VAR Word  'Data value to transmit 0 to 65535
      XBData4  VAR Byte  '1st digit
      XBData3  VAR Byte  '2nd
      XBData2  VAR Byte  '3rd
      XBData1  VAR Byte  '4th
      XBData0  VAR Byte  '5th
      HIGH TX ' Idle transmit pin
      DEBUG CLS, "API TX - Configuring XBee..."
      PAUSE 2000 ' Guard time for command sequence
      SEROUT TX,Baud,["+++"] ' Enter command mode
      SEROUT TX,Baud,["ATNI XBee API TX",CR, ' Set description
                      "ATMY ", HEX 2,CR, ' Set node address
                      "ATDL ", HEX 1,CR, ' Set destination node address
                      "ATD6 1",CR, ' Use RTS for flow control
                      "ATAP 2",CR, ' API with escape characters
                      "ATCN",CR] ' Exit command mode
      PAUSE 2000
      XBTxID = XBTx16   'set for 16-bit transmit packet
      XBDestMSB = $00   '$FF for broadcast
      XBDestLSB = $01   '$FF for broadcast
    Main:
      FOR XBFrame = 11 TO 50
        XBData = 1000 + (5 * XBFrame)
    '    RANDOM XBData
        GOSUB XBeeTx16
        DEBUG CR
        PAUSE 500
      NEXT
      PAUSE 3000
    '  GOTO main
      END
    XBeeTx16:
    'Convert to character by adding "0" (decimal 48) to each digit
      XBData4 = ( XBData DIG 4) + "0"
      XBData3 = ( XBData DIG 3) + "0"
      XBData2 = ( XBData DIG 2) + "0"
      XBData1 = ( XBData DIG 1) + "0"
      XBData0 = ( XBData DIG 0) + "0"
      XBCheckSum = XBTxID + XBFrame + XBDestMSB + XBDestLSB + XBOptions + XBData0 + XBData1 + XBData2 + XBData3 + XBData4
      XBCheckSum = 255 - XBCheckSum
      DEBUG "Packet Type(", IHEX2 XBTxID, ")", CR
      DEBUG "Frame Counter: ", DEC XBFrame, CR
      DEBUG "Packet Destination: (", IHEX2 XBDestMSB, "), (", IHEX2 XBDestLSB, ")",CR
      DEBUG "Options: ", IHEX2 XBOptions, CR
      DEBUG "Data: (", XBData4, "), (", XBData3, "), (", XBData2,"), (", XBData1,"), (", XBData0,")",CR
      DEBUG "Checksum: ", DEC XBCheckSum, CR
      DEBUG "Dump: ", IHEX XBDelim, IHEX 0,IHEX 10, IHEX XBTxID,IHEX XBFrame,IHEX XBDestMSB,IHEX XBDestLSB,IHEX XBData0,IHEX XBData1,IHEX XBData2,IHEX XBData3,IHEX XBData4,IHEX XBCheckSum,CR
      SEROUT TX, Baud, [XBDelim,0,10,XBTxID,XBFrame,XBDestMSB,XBDestLSB,XBOptions,XBData4,XBData3,XBData2,XBData1,XBData0,XBCheckSum]
    'SEROUT TX, Baud, [XBDelim,0,10,XBTxID,XBEsc,51,170,170,0,1,1,2,3,4,140]
    ' TX Good Status packet should look like: XBDelim,0,3,XBTxStat,XBFrame,0,34
      SERIN RX, Baud,3000,main2, [WAIT(xbDelim),SKIP 2,WAIT(XBTxStat),XBData0,XBResult,SKIP 1]
      DEBUG "Packet:", DEC XBData0, ", Tx Result: ", IHEX XBResult,CR
    Main2:
      RETURN
    Receive
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
        T1200       CON     813
        T2400       CON     396
        T4800       CON     188
        T9600       CON     84
        T19K2       CON     32
      #CASE BS2SX, BS2P
        T1200       CON     2063
        T2400       CON     1021
        T4800       CON     500
        T9600       CON     240
        T19K2       CON     110
      #CASE BS2PX
        T1200       CON     3313
        T2400       CON     1646
        T4800       CON     813
        T9600       CON     396
        T19K2       CON     188
    #ENDSELECT
    'structure of 16 bit RX packet
      Delim      VAR Byte  'should be 0x7E
      LenMSB     VAR Byte
      LenLSB     VAR Byte
      APIID      VAR Byte  'should be 0x81
      SrcMSB     VAR Byte  'high part of sending XBee's address
      SrcLSB     VAR Byte  'low part of sending XBee's address
      RSSI       VAR Byte  'signal strength: 0x17-0x5C (XBee), 0x24-0x64 (XBee-PRO)
      Opts       VAR Byte
      XBData4    VAR Byte
      XBData3    VAR Byte
      XBData2    VAR Byte
      XBData1    VAR Byte
      XBData0    VAR Byte
      XBCheckSum VAR Byte
      XBData     VAR Word
    DEBUG CLS, "API RX - Configuring XBee..."
                    "ATMY ", HEX 1,CR, ' Set node address
                    "ATDL ", HEX 2,CR, ' Set destination node address
    PAUSE 1000
    DEBUG "Ready!", CR
    DO
      SERIN RX, Baud, [WAIT(xbDelim), LenMSB, LenLSB, APIID, SrcMSB, SrcLSB, RSSI, Opts, XBData4, XBData3, XBData2, XBData1,XBData0, XBCheckSum]
    '  SERIN RX, Baud, [WAIT(xbDelim),SKIP 2,WAIT(XBRx16), SKIP 2, RSSI, Opts, XBData4, XBData3, XBData2, XBData1,XBData0, XBCheckSum]
    'reconstruct transmitted word from received digits
      XBData = (10000 *(XBData4 - "0")) + (1000 *(XBData3 - "0")) + (100 *(XBData2 - "0")) + (10 *(XBData1 - "0")) + (XBData0 - "0")
      DEBUG IHEX APIID," ",IHEX SrcMSB," ",IHEX SrcLSB," ",IHEX Opts," ", XBData4,XBData3,XBData2,XBData1,XBData0, " (", DEC5 XBData, ")  RSSI: -", DEC RSSI, " dBm", CR
    LOOP
    END
  • StephenMooreStephenMoore Posts: 188
    @$WMc%
    Hi and thanks for looking at my progs. My PC interface is written actually for National Instruments LabWindows but here are the Tx and Rx methods. If you would like the .exe or the full up code you are welcome to it. I am planning on converting it to Microsoft Visual Studio Express since you can get that for free from Microsoft.
    #include <utility.h>
    #include "XbeeTerminal.h"
    #include <formatio.h>
    #include <rs232.h>
    #include <ansi_c.h>
    #include <cvirte.h>
    #include <userint.h>
    static int panelHandle;
    static int panelHandle2;
    static int panelHandle3;
    //============================AT style API frames=======================
    typedef struct XbeeATcmdObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;  //0x08
    	int frameID;
    	int cmd;
    	int param;
    	char checkSum[1];
    }XbeeATcmdObj;
    typedef struct XbeeATcmdQparamObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x09
    	int frameID;
    	int cmd;
    	int param;
    	char checkSum[1];
    }XbeeATcmdQparamObj;
    typedef struct XbeeRemoteATcmdObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;  //0x17
    	int frameID;
    	int destAddrHi;
    	int destAddrLo;
    	int netAddr;
    	int options;
    	int cmd;
    	int param;
    	char checkSum[1];
    }XbeeRemoteATcmdObj;
    typedef struct XbeeATcmdStatusObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;  //0x88
    	int frameID;
    	int cmd;
    	int cmdStatus;
    	char checkSum[1];
    }XbeeATcmdStatusObj;
    //=============================API Transmit frames =====================
    typedef struct XbeeTxObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x10
    	int frameID;
    	int destAddrHi;
    	int destAddrLo;
    	int netAddr;
    	int radius;
    	int options;
    	char message[256];
    	char checkSum[1];
    }XbeeTxObj;
    typedef struct XbeeTxExpObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x11
    	int frameID;
    	int destAddrHi;
    	int destAddrLo;
    	int netAddr;
    	int sourceEndPoint;
    	int destEndpoint;
    	int ClusterID;
    	int ProfileID;
    	int radius;
    	int options;
    	char message[256];
    	char checkSum[1];
    }XbeeTxExpObj;
    typedef struct XbeeTxStatusObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x8B
    	int frameID;
    	int netAddr;
    	int retries;
    	int status;
    	int discovery;
    	char checkSum[1];
    }XbeeTxStatusObj;
    //================================API Receive frames============================
    typedef struct XbeeRxObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x90
    	int sourceAddrHi;
    	int sourceAddrLo;
    	int sourcenetAddr;
    	int options;
    	char message[256];
    	char checkSum[1];
    }XbeeRxObj;
    typedef struct XbeeRxIOsampleObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x92
    	int sourceAddrHi;
    	int sourceAddrLo;
    	int sourcenetAddr;
    	int options;
    	int numSamples;
    	int digMask1;
    	int digMask2;
    	int analogMask;
    	int digData;
    	int analogData;
    	char checkSum[1];
    }XbeeRxIOsampleObj;
    //=================================General purpose API frames====================
    typedef struct XbeeStatusObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x8A
        int status;
    	char checkSum[1];
    }XbeeStatusObj;
    typedef struct XbeeSourceRouteObj
    	int start;
    	int lenMSB;
    	int lenLSB;
    	int frameType;   //0x21
    	int frameID;
    	int destAddrHi;
    	int destAddrLo;
    	int netAddr;
    	int options;
    	int numAddresses;
    	int addr1;       //neighbor closest to dest
    	int addr2;
    	int addr3;       //neighbor closest to source
    	int cmdParam;
    	char checkSum[1];
    }XbeeSourceRouteObj;
    void CVICALLBACK RxComPort (int portNumber, int eventMask, void *callbackData);
    XbeeRemoteATcmdObj		*XbeeRemoteATcmdTx;
    XbeeATcmdStatusObj      *XbeeATcmdTxStatus;
    XbeeTxObj    			*XbeeTx;
    XbeeTxStatusObj			*XbeeTxStatus;
    XbeeRxObj				*XbeeRx;
    XbeeRxIOsampleObj       *XbeeRxIOsample;
    int ComMode;
    int ComPort;
    int changeDetect;
    int pullUp;
    int main (int argc, char *argv[])
    	if (InitCVIRTE (0, argv, 0) == 0)
    		return -1;	/* out of memory */
    	if ((panelHandle = LoadPanel (0, "XbeeTerminal.uir", PANEL)) < 0)
    		return -1;
    	DisplayPanel (panelHandle);
    //	GetCtrlVal (PANEL, PANEL_NUMERIC_5, &portA);
    	ComMode = 0x01;
    	ComPort = 0x03;
    	OpenComConfig (ComPort, "", 9600, 0, 8, 1, 512, 512);
    	InstallComCallback (ComPort, 1, 0, 0, RxComPort, 0);
    // Set-up default XbeeTxObj values
    	XbeeTx = (XbeeTxObj *)malloc(sizeof(XbeeTxObj));
    	XbeeTx->start 		= 0x7E;
    	XbeeTx->frameType	= 0x10;
    	XbeeTx->frameID     = 0x01;
    	XbeeTx->destAddrHi  = 0x0013A200;   //For all Digi Xbee radios
    //	XbeeTx->destAddrLo  = 0x40683F5D;   // my robot Xbee
    	XbeeTx->destAddrLo  = 0x406932B4;   // my dev Xbee
    	XbeeTx->netAddr   	= 0xFFFE;       //Leave at this value when using 8 byte address mode
    	XbeeTx->radius      = 0x00;         //Value 0x00 allow max hops
    	XbeeTx->options     = 0x00;			//Set to 0x01 to disable ACK
    // Set-up default XbeeRxObj values
    	XbeeRx = (XbeeRxObj *)malloc(sizeof(XbeeRxObj));
    // Set-up default XbeeTxStatusObj values
    	XbeeTxStatus = (XbeeTxStatusObj *)malloc(sizeof(XbeeTxStatusObj));
    // Set-up default XbeeRemoteATcmdObj values
    	XbeeRemoteATcmdTx = (XbeeRemoteATcmdObj *)malloc(sizeof(XbeeRemoteATcmdObj));
    	XbeeRemoteATcmdTx->start      =0x7E;
    	XbeeRemoteATcmdTx->lenMSB     =0x00;
    	XbeeRemoteATcmdTx->frameType  =0x17;
    	XbeeRemoteATcmdTx->frameID    =0x01;
    	XbeeRemoteATcmdTx->destAddrHi =0x0013A200;
    	XbeeRemoteATcmdTx->netAddr    =0xFFFE;
    	XbeeRemoteATcmdTx->options    =0x02;     //0x00 = no ACK, 0x02 = apply changes
    // Set-up default XbeeATcmdStatusObj values
    	XbeeATcmdTxStatus = (XbeeATcmdStatusObj *)malloc(sizeof(XbeeATcmdStatusObj));
    // Set-up default XbeeRxIOsampleObj values
    	XbeeRxIOsample = (XbeeRxIOsampleObj *)malloc(sizeof(XbeeRxIOsampleObj));
    	changeDetect = 0x00;
    	pullUp		 = 0x00;
    	RunUserInterface ();
    	free(XbeeTx);
    	free(XbeeTxStatus);
    	free(XbeeRx);
    	free(XbeeRemoteATcmdTx);
    	free(XbeeATcmdTxStatus);
    	CloseCom (ComPort);
    	DiscardPanel (panelHandle);
    	return 0;
    int CVICALLBACK panelCB (int panel, int event, void *callbackData,
            int eventData1, int eventData2)
        if (event == EVENT_CLOSE)
         QuitUserInterface (0);
        return 0;
    int TxAPI(void)
    	char message[18 + strlen(XbeeTx->message)];
    	int index;
    	XbeeTx->lenMSB		= (0x0E + strlen(XbeeTx->message))/256;				 // 0x0E added for frame size
    	XbeeTx->lenLSB		= 0x0E + strlen(XbeeTx->message) - (XbeeTx->lenMSB*256);  // masks off lower byte
    	XbeeTx->checkSum[0] = 0x00;
     	message[0]  = XbeeTx->start;
        message[1]  = XbeeTx->lenMSB;
    	message[2]  = XbeeTx->lenLSB;
    	message[3]  = XbeeTx->frameType;
    	message[4]  = XbeeTx->frameID;
    	for (index = 0; index <4; index ++)
    	message[index + 5]  = (XbeeTx->destAddrHi >> (3-index)*8) & 0xFF;
    	message[index + 9]  = (XbeeTx->destAddrLo >> (3-index)*8) & 0xFF;
    	message[13] = (XbeeTx->netAddr >> 8) & 0xFF;
    	message[14] =  XbeeTx->netAddr & 0xFF;
    	message[15] = XbeeTx->radius;
    	message[16] = XbeeTx->options;
    	for (index = 0; index < strlen(XbeeTx->message); index ++)
    		message[index + 17] = XbeeTx->message[index];
    	for (index = 3; index < (17 + strlen(XbeeTx->message)); index ++)
    		XbeeTx->checkSum[0] += message[index];
    	message[17 + strlen(XbeeTx->message)] = 0xFF - XbeeTx->checkSum[0];
    	ComWrt(ComPort, message, 18 + strlen(XbeeTx->message));
    	while(GetOutQLen(ComPort)>0);
    	return 0;
    int TxRemoteATcmdAPI(void)
    	int index;
    	char message[4 + XbeeRemoteATcmdTx->lenLSB];
     	message[0]  = XbeeRemoteATcmdTx->start;
        message[1]  = XbeeRemoteATcmdTx->lenMSB;
    	message[2]  = XbeeRemoteATcmdTx->lenLSB;
    	message[3]  = XbeeRemoteATcmdTx->frameType;
    	message[4]  = XbeeRemoteATcmdTx->frameID;
    	message[index + 5]  = (XbeeRemoteATcmdTx->destAddrHi >> (3-index)*8) & 0xFF;
    	message[index + 9]  = (XbeeRemoteATcmdTx->destAddrLo >> (3-index)*8) & 0xFF;
    	message[13] = (XbeeRemoteATcmdTx->netAddr >> 8) & 0xFF;
    	message[14] =  XbeeRemoteATcmdTx->netAddr & 0xFF;
    	message[15] = XbeeRemoteATcmdTx->options;
    	message[16] = (XbeeRemoteATcmdTx->cmd >> 8) & 0xFF;
    	message[17] = XbeeRemoteATcmdTx->cmd  & 0xFF;
    	if(XbeeRemoteATcmdTx->lenLSB == 0x10)
    		message[18] = XbeeRemoteATcmdTx->param;
    	for (index = 3; index < (3 + XbeeRemoteATcmdTx->lenLSB); index ++)
    	message[3 + XbeeRemoteATcmdTx->lenLSB] = 0xFF - XbeeTx->checkSum[0];
    	ComWrt(ComPort, message, 4 + XbeeRemoteATcmdTx->lenLSB);
    	return 0;
    void CVICALLBACK RxComPort(int portNumber, int eventMask, void *callbackData)
    	char RxMsg[128];
    	char msgHeader[4];
    	int  msgLen;
    	int  index;
    	char addrLo[5];
    	int analogIndex;
    	int analogValue;
    	float scaledAnalog;
    	int switchVal;
    	InstallComCallback(ComPort, 0x00, 0x00, 0x7E, RxComPort, NULL);
    	if(!ComMode)
    		SetComTime(ComPort, .25);
    		ComRd(ComPort, XbeeRx->message, 128);
    		SetCtrlVal(PANEL, PANEL_STRING_2, XbeeRx->message);
    		goto done;
    	ComRd(ComPort, msgHeader, 4);
    	XbeeRx->start     = msgHeader[0];
    	XbeeRx->lenMSB    = msgHeader[1];
    	XbeeRx->lenLSB    = msgHeader[2];
    	XbeeRx->frameType = msgHeader[3]&0xFF;
    	msgLen = XbeeRx->lenMSB * 256 + XbeeRx->lenLSB;
    	ComRd(ComPort, RxMsg, msgLen);
    	switch(XbeeRx->frameType)
    	case 0x90:
    		  CopyString (XbeeRx->message, 0, RxMsg, 11, msgLen-12);
    		  XbeeRx->sourceAddrHi = 0;
    		  XbeeRx->sourceAddrLo = 0;
    		  XbeeRx->sourcenetAddr= 0;
    		  for(index = 0; index < 4; index++)
    		  XbeeRx->sourceAddrHi = (XbeeRx->sourceAddrHi << 8) + RxMsg[index];
    		  XbeeRx->sourceAddrLo = (XbeeRx->sourceAddrLo << 8) + RxMsg[index + 4];
    		  XbeeRx->sourcenetAddr = (XbeeRx->sourcenetAddr + RxMsg[8])<<8 + RxMsg[9];
    		  SetCtrlVal(PANEL, PANEL_NUMERIC, XbeeRx->sourceAddrLo);
    //		  SetActivePanel(panelHandle3);
    //		  GetCtrlVal(panelHandle3, PANEL_4_BINARYSWITCH, &switchVal);
    //		  if (switchVal==1)
    //		      UNVmessage();
    	break;
    	case 0x8B:
    		XbeeTxStatus->status = RxMsg[4];
    		if(XbeeTxStatus->status != 0x00)
    			SetCtrlVal(PANEL, PANEL_LED, 1);
    	//	printf("Message Tx OK.");
    	break;
    	case 0x92:
    	//	printf("IO sample received.\n");
    		XbeeRxIOsample->digMask1	= RxMsg[12];
    		XbeeRxIOsample->digMask2	= RxMsg[13];
    		XbeeRxIOsample->analogMask	= RxMsg[14];
    		// Set digital input 1
    		if (XbeeRxIOsample->digMask2 & 0x1)
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED, ATTR_DIMMED, 0);
    		   	if (RxMsg[16] & 0x1)
    			   	SetCtrlVal(panelHandle2,PANEL_2_LED, 1);
    		   	else
    		   		SetCtrlVal(panelHandle2,PANEL_2_LED, 0);
    		else
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED, ATTR_DIMMED, 1);
    		// Set digital input 2
    		if (XbeeRxIOsample->digMask2 & 0x2)
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED_2, ATTR_DIMMED, 0);
    		   	if (RxMsg[16] & 0x2)
    			   	SetCtrlVal(panelHandle2,PANEL_2_LED_2, 1);
    		   	else
    		   		SetCtrlVal(panelHandle2,PANEL_2_LED_2, 0);
    		else
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED_2, ATTR_DIMMED, 1);
    		// Set digitial input 3
    		if (XbeeRxIOsample->digMask2 & 0x4)
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED_3, ATTR_DIMMED, 0);
    		   	if (RxMsg[16] & 0x4)
    			   	SetCtrlVal(panelHandle2,PANEL_2_LED_3, 1);
    		   	else
    		   		SetCtrlVal(panelHandle2,PANEL_2_LED_3, 0);
    		else
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED_3, ATTR_DIMMED, 1);
    		// Set digital input 4
    		if (XbeeRxIOsample->digMask2 & 0x8)
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED_4, ATTR_DIMMED, 0);
    		   	if (RxMsg[16] & 0x8)
    			   	SetCtrlVal(panelHandle2,PANEL_2_LED_4, 1);
    		   	else
    		   		SetCtrlVal(panelHandle2,PANEL_2_LED_4, 0);
    		else
    			SetCtrlAttribute(panelHandle2,PANEL_2_LED_4, ATTR_DIMMED, 1);
    		// Check to see if digital IO has been set
    		if ((XbeeRxIOsample->digMask1 + XbeeRxIOsample->digMask2)!=0)
    			 analogIndex = 17;
    		else analogIndex = 15;
    		// Set analog input 1
    		if (XbeeRxIOsample->analogMask & 0x01)
    			analogValue = RxMsg[analogIndex] * 256 + RxMsg[analogIndex+1];
    			scaledAnalog =  analogValue * 1.2 / 1024;
    		//	printf("Analog value = %x\n", analogValue);
    		//	printf("Scaled value = %f\n", scaledAnalog);
    			SetCtrlAttribute(panelHandle2,PANEL_2_NUMERIC, ATTR_DIMMED, 0);
    			SetCtrlVal(panelHandle2,PANEL_2_NUMERIC, scaledAnalog);
    		else
    		{	scaledAnalog = 0;
    			SetCtrlAttribute(panelHandle2,PANEL_2_NUMERIC, ATTR_DIMMED, 1);
    /*		// Set analog input 2
    		if (XbeeRxIOsample->analogMask & 0x02)
    			analogIndex = analogIndex + 1;
    			SetCtrlAttribute(panelHandle2,PANEL_2_NUMERIC_2, ATTR_DIMMED, 0);
    			SetCtrlVal(panelHandle2,PANEL_2_NUMERIC_2, scaledAnalog);
    		else
    		{	scaledAnalog = 0;
    			SetCtrlAttribute(panelHandle2,PANEL_2_NUMERIC_2, ATTR_DIMMED, 1);
    		XbeeRemoteATcmdTx->cmd = 0x49;   // ascii I
    		XbeeRemoteATcmdTx->cmd = (XbeeRemoteATcmdTx->cmd << 8) + 0x52;  //ascii R
    		XbeeRemoteATcmdTx->param = 0x00;
    		TxRemoteATcmdAPI();
       	break;
    	case 0x97:
    		 XbeeATcmdTxStatus->cmd = RxMsg[11];
    		 XbeeATcmdTxStatus->cmd = (XbeeATcmdTxStatus->cmd)<<8 + RxMsg[12];
    		 XbeeATcmdTxStatus->cmdStatus = RxMsg[13];
    	//	 printf("Response for  AT cmd = %x%x", RxMsg[11],RxMsg[12]);
    		// printf("Response for  AT cmd = %x", XbeeATcmdTxStatus->cmd);
    	//	 printf(" is %x", XbeeATcmdTxStatus->cmdStatus);
    	//	 printf("\n");
    	break;
    	default:
    			 printf("No handler for message = 0x");
    	         printf("%x", XbeeRx->frameType);
    			 printf("\n");
    			 break;
    	}  // end of switch
    done:
    	InstallComCallback(ComPort, 0x01, 0x00, 0x7E, RxComPort, NULL);
    int CVICALLBACK TxComPort (int panel, int control, int event,
    		void *callbackData, int eventData1, int eventData2)
    	switch (event)
    		case EVENT_COMMIT:
    			SetCtrlVal(PANEL, PANEL_LED, 0);
    			GetCtrlVal(PANEL, PANEL_STRING, XbeeTx->message);
    			SetCtrlVal(PANEL, PANEL_STRING, "");
    			if (ComMode)
    				TxAPI();
    			else
    				ComWrt(ComPort, XbeeTx->message, strlen(XbeeTx->message));
    			break;
    	return 0;
    int CVICALLBACK QuitCallback (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    			CloseCom(ComPort);
    			break;
    	return 0;
    int CVICALLBACK openPort (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    			GetCtrlVal (PANEL, PANEL_NUMERIC_5, &ComPort);
    			break;
    	return 0;
    int CVICALLBACK destSet (int panel, int control, int event,
    	int radioID;
    	switch (event)
    		case EVENT_COMMIT:
    			GetCtrlVal(PANEL, PANEL_RING, &radioID);
    			switch (radioID)
    				case 0:
    					XbeeTx->destAddrLo = 0x4066C4F9;
    					break;
    				case 1:
    					break;
    				case 2:
    					XbeeTx->destAddrLo = 0x40686462;
    					break;
    				case 3:
    					XbeeTx->destAddrLo = 0x40683F59;
    					break;
    			    case 4:
    					break;
    			SetCtrlVal(PANEL, PANEL_NUMERIC_2, XbeeTx->destAddrLo);
    			break;
    	return 0;
    int CVICALLBACK displayIO (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    		if ((panelHandle2 = LoadPanel (0, "XbeeTerminal.uir", PANEL_2)) < 0)
    		return -1;
    			DisplayPanel(panelHandle2);
    			break;
    	return 0;
    int CVICALLBACK getIOsample (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    		XbeeRemoteATcmdTx->lenLSB     = 0x10;
    		XbeeRemoteATcmdTx->destAddrLo = XbeeTx->destAddrLo;
    		XbeeRemoteATcmdTx->param = 0xFE;
    		TxRemoteATcmdAPI();
    		break;
    	return 0;
    int CVICALLBACK closeIOpanel (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    			DiscardPanel(panelHandle2);
    			break;
    	return 0;
    int CVICALLBACK configIO (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    			if ((panelHandle3 = LoadPanel (0, "XbeeTerminal.uir", PANEL_3)) < 0)
    		return -1;
    			DisplayPanel(panelHandle3);
    			break;
    	return 0;
    int CVICALLBACK closeConfigPanel (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    			DiscardPanel(panelHandle3);
    			break;
    	return 0;
    int CVICALLBACK configChannel (int panel, int control, int event,
    	int chan;
    	int mode;
    	switch (event)
    		case EVENT_COMMIT:
    		GetCtrlVal(panelHandle3, PANEL_3_RING_2, &chan);
    		switch (chan)
    			case 0: case 1: case 2: case 3: case 4: case 5: case 6: case 7:
    	    	XbeeRemoteATcmdTx->cmd = 0x44;   // ascii D
    			XbeeRemoteATcmdTx->cmd = (XbeeRemoteATcmdTx->cmd << 8) + (chan + 48);  // ascii 0-7
    			break;
    			case 10: case 11: case 12:
    			XbeeRemoteATcmdTx->cmd = 0x50;   // ascii P
    			XbeeRemoteATcmdTx->cmd = (XbeeRemoteATcmdTx->cmd << 8) + (chan + 38);  // ascii 0-2
    			break;
    		GetCtrlVal(panelHandle3, PANEL_3_RING, &mode);
        	XbeeRemoteATcmdTx->param = mode;     // ascii 0-5
    		TxRemoteATcmdAPI();
    	break;
    	return 0;
    int CVICALLBACK setPullUp (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    		XbeeRemoteATcmdTx->cmd = (XbeeRemoteATcmdTx->cmd << 8) + 0x52;  // R
    		if (pullUp == 0x00)
    			pullUp = 0x1F;
    		else
    			pullUp = 0x00;
    		XbeeRemoteATcmdTx->param = pullUp;
    		TxRemoteATcmdAPI();
    			break;
    	return 0;
    int CVICALLBACK setChangeDetect (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    		XbeeRemoteATcmdTx->cmd = (XbeeRemoteATcmdTx->cmd << 8) + 0x43;  // C
    		if (changeDetect == 0x00)
    			changeDetect = 0x1F;
    		else changeDetect = 0x00;
    		 XbeeRemoteATcmdTx->param = changeDetect;
    		 TxRemoteATcmdAPI();
    			break;
    	return 0;
    int CVICALLBACK setComMode (int panel, int control, int event,
    	switch (event)
    		case EVENT_COMMIT:
    			GetCtrlVal(PANEL, PANEL_BINARYSWITCH,  &ComMode);
    			SetCtrlAttribute(PANEL, PANEL_COMMANDBUTTON_2, ATTR_VISIBLE, ComMode);
    			SetCtrlAttribute(PANEL, PANEL_COMMANDBUTTON_3, ATTR_VISIBLE, ComMode);
    			break;
    	return 0;
    The hard part is the Rx method since it has so many possible results.
    SM
    @ Ron Czapala
    Which Xbee are you using?
    @ Ron Czapala
    I've got the Series 1 XBee PRO 60mW and XBee PRO 1mW modules.
