S2 internal Pen Lifter and a couple questions for Phil
W9GFOW9GFO Posts: 3,730
edited March 2012 in Robotics Vote Up0Vote Down
First, here's the Pen Lifter, it works awesomely well if I do say so myself...
See the blog entry for more details.
Now for some questions;
1. The speaker makes a constant but quiet tick tick tick at about 10 hz. Is that normal?
2. Could you take a look at this code? The goal is to control the S2 using my XBee equipped remote controller. The goal is met, it does control it quite well. The problem however is that I cannot get the S2 to maintain a perfectly steady speed. It is as if every second or two the motors will stutter for just a moment even though they are receiving a steady move value.
3. Related to the above perhaps, if I stop the S2 suddenly and then very gently reverse direction, it will lurch slightly.
If I have not described the issues adequately I can put a video on YouTube.
Rich H
  • 49 Comments sorted by Date Added Votes
  • Martin_HMartin_H Posts: 4,024
    edited December 2010 Vote Up0Vote Down
    That is a really cool mod. I make that to my S1.
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,492
    Rich,
    Very nice pen lifter! And a beautiful installation! (I'm amazed it all fit.) In response to your questions:
    1. No, the ticking is not normal. (At least I've never noticed it.) Does it do it all the time? What about if you don't start the audio cog?
    2. The "stuttering" you observe is related to the encoder resolution and the way wheel movements are coordinated. In the motor driver object, the motion of each wheel is monitored in relation to the other one. If one wheel should get ahead, it will not receive PWM pulses until the other wheel has caught up with it. That way, if you grip one of the wheels during a movement to slow it down, the other will slow proportionally. Now, if the motion values going to the two wheels differ by a small number, say, two (e.g. 1000 and 1002), there will be two points along the trajectory where one wheel will appear to get ahead of the other (just due to the encoder math) and will hesitate while the other "catches up". This may be the "stutter" that you notice.
    One may also notice a stutter during the drawing routines when drawing arcs. For example, when drawing a full circle, it is necessary to break it into two arcs. Sometimes the correct ending point for the first arc will not have integer coordinates, and you have to round them to integers. If, when the second arc begins, the arc radius is deemed too small for the distance to the ending point, the drawing software will move toward the ending point in a straight line, far enough to make up the extra distance, then draw the arc.
    3. The lurching you see upon reversing direction may be related to backlash in the gearbox, but I'm not sure. If you post an example program that produces this behavior, I'll have a look at it.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • W9GFOW9GFO Posts: 3,730
    Thanks Phil,
    I've just discovered that the ticking vanishes completely when I turn off the remote controller and returns after it has turned back on and booted up - and is in sync with the XBee TX Led on the controller.
    Looking at the well documented PASM motor code it looks like there should be something that I could do to disable the encoders, or at least the part where one is compared against the other. But since I don't really know PASM I do not know how to accomplish that.
    I doubt that the lurching is gear backlash. It only occurs after the S2 is stopped abruptly while moving at faster than half speed. As soon as it begins to move again it appears to be trying to make up some encoder counts.
    Rich H
  • NikosGNikosG Posts: 605
    Hi Phil,
    Something about the problem with circles....(from LOGO Theory)
    Try this algorithm: REPEAT(36) FORWARD (5 cm or any distance) ROTATE-RIGHT (10 degrees)
    When I say Forward I mean both whees must have the same direction and velocity. If the s2 can rotate precisely 10 degrees you 'll have a perfect circle after the 36 steps.
    I have tried this method 6 years ago with a homemade robot (with very cheap DC motors with no accuracy) and I had great results.
    Unfortunately I don't have a s2 to try this but I believe that you 'll have result.
    Nikos Giannakopoulos
    W9GFO - if you want to control the s2's wheel motors directly youself without using the s2 object or the encoders you could use something like this example
    Con                                      ''s2 direct wheel motor control
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      pwm = 16                               ''pwm base io for s2
    Var
    Obj
      pw : "pwmx8"                           ''pwm object
    Pub main
      pw.start(16, %00001100, 20_000)        ''start pwm object on pwm base i/o pin @ 20khz
      dira[16..17]~~                         ''set s2's motor direction control i/o pins to output
      repeat
                  'left      right
        move_robot(-75,      255)            ''set s2's left wheel slow reverse, set s2's right wheel maximum forward
    Pub move_robot(left_wheel, right_wheel)  ''set s2's left & right wheel motor's speed from -255 maximum reverse to 255 maximum forward, 0 = stop
      left_wheel := -255 #> left_wheel <# 255
      right_wheel := -255 #> right_wheel <# 255
      ifnot right_wheel & $80_00_00_00
        outa[pwm + 1] := 1
        pw.duty(pwm + 3, right_wheel & $ff)
      else
        outa[pwm + 1] := 0
        pw.duty(pwm + 3, (0 - right_wheel) & $ff)
      ifnot left_wheel & $80_00_00_00
        outa[pwm] := 1
        pw.duty(pwm + 2, left_wheel & $ff)
      else
        outa[pwm] := 0
        pw.duty(pwm + 2, (0 - left_wheel) & $ff)
    Fix it, if it ain't broke! .......... D Rat .......... Dave ..........
    Thanks Dave,
    Not sure why I didn't go that direction, maybe it's because I was hoping to use as much of the 'native' S2 code as possible. I think using a separate driver object is very sensible.
    Rich H
    w9gfo - sorry i posted the wrong file - use the one thats attached in my above post now to get the motors to run the right direction
    The file you attached worked just great for me.
    Rich H
    edited January 2011 Vote Up0Vote Down
    I've added a video of the pen lifter to the blog.
    Here's a direct link.
    http://www.youtube.com/watch?v=FqahLvqI-dk
    Rich H
    That's some pretty nice scribblin! What is that controller you are using?
    Thanks!
    The controller is described in this thread.
    RIch H
    Very cool! I missed that one.
  • ercoerco Posts: 18,647
    GREAT Scribblin', Rich! I got a bad S2, turns out. I'll have to get mine swapped out before I can Scribble!
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
    Thanks!
    Here's another;
    Rich H
  • WhitWhit Posts: 3,736
    Super cool! I thought I had done some cool scribbling...
    Whit+
    Rich,
    That's even better repeatability than I would've guessed possible. Did you use the drawing commands in the S2 object? Did you have to tweak the calibration coefficients? (And what's with "SAINTS"? For Whit's benefit, I hope! Go Seahawks! Not that I give a rip. It's just for editorial balance. :) )
    It was all done with move_to and arc_to commands. Calibration coefficients? Didn't even know there were any.
    "Saints" is for the Interlake Saints Robotics Team.
    Rich H
    No matter: it doesn't look like you need 'em!
    Nice save! Um, go Saints! Yeah!
    Here is a larger version. By Larger, I mean the letters are scaled up four times.
    http://forums.parallax.com/entry.php?89-Parallax-S2-writes-quot-Saints-quot-in-big-letters
    And here is the code for the "A", any idea why it messed it up? It seems like it lost some encoder counts on the first two arcs.
    Pub A
     s2.move_to(420, 0)
     pen_down
     s2.begin_path
     s2.move_to(420, 416)
     s2.arc_to(544, 540, -124)
     s2.move_to(656, 540)
     s2.arc_to(780, 416, -124)
     s2.move_to(780, 0)
     s2.move_to(660, 0)
     s2.move_to(660, 180)
     s2.move_to(540, 180)
     s2.move_to(540, 0)
     s2.move_to(420, 0)
     s2.end_path
     pen_up
     s2.move_to(540, 300)
     pen_down
     s2.begin_path
     s2.move_to(540, 388)
     s2.arc_to(568, 420, -32)
     s2.move_to(628, 420)
     s2.arc_to(660, 388, -32)
     s2.move_to(660, 300)
     s2.end_path
     pen_up
    Rich H
    To properly scribble about my saints, you will need to scribble "Who Dat?" The church's saints are another matter.
    Great job Rich!
    Whit+
    Okay - Time to re-program to make it say SEA HAWKS...
    who dat??? :frown:
    Whit+
    Or, keeping it on-topic by giving a bow to Georgia Tech's Scribbler/S2 accessory: what a FLUKE! :)
    edited March 2012 Vote Up0Vote Down
    W9GFO wrote: »
    Pub A
     s2.move_to(420, 0)
     pen_down
     s2.begin_path
     s2.move_to(780, 0)
     s2.move_to(660, 0)
     s2.move_to(540, 0)
     s2.move_to(420, 0)
     s2.end_path
     pen_up
     pen_down
     s2.begin_path
     s2.end_path
     pen_up
    Rich H
    Hi Rich,
    Inspired from your pen lifter I created an advanced Internal pen lifter. Althought the pen lifter lifts the pen Up and down perfect using the spin code: "s2_pen_lifter_test" it is not work in conjunction with the S2 Object. When the robot moves straight or makes arcs it is not able to move the pen up and down. I would be thankful if you could give some information about the methods "pen_up" and "pen_down" that you use in your code (above). Do you use multitasking for those methods?
    Thank you
    Nikos Giannakopoulos.
    The pen_up and pen_down methods are very simple, something like this.
    con
    pen = 1
    up = 1200
    pen_up
    servo.set(pen, up)
    It will only work this way between line segments.
    If you wanted to create dots or dashes during the line segment I think you could write a method that moves the pen based upon encoder counts - or at the minimum, time based.
    Thank you Rich,
    I had already tried your advice but nothing....
    here is the code:
    CON
       _CLKMODE = XTAL1 + PLL16X
       _CLKFREQ = 5_000_000
       Up    =  2080
       Down  = 1600
        ServoPen  = 5
    OBJ
    s2 : "S2"
    SERVO : "Servo32v7"    '-------------- for pen lifter
    PUB Main
      Pen_Down '---------------------------------
      S2.start
       S2.button_mode(true, true)
       S2.set_led(s2#POWER, s2#BLUE)
       S2.start_motors
       S2.set_speed(7)
       S2.here_is(0,0)
     S2.begin_path
       S2.move_to(300,0)
       Pen_Up
       S2.move_to(600,0)
       Pen_Down
       S2.move_to(900,0)
       S2.move_to(900,300)
        Pen_Up
       S2.move_to(900,600)
        Pen_Down
       S2.move_to(900,900)
       S2.move_to(600,900)
       Pen_Up
       S2.move_to(300,900)
         Pen_Down
       S2.move_to(0,900)
       S2.move_to(0,600)
     Pen_Up
       S2.move_to(0,300)
      Pen_Down
       S2.move_to(0,0)
     S2.end_path
    PUB    Pen_up
        SERVO.Start                 ' Start servo handler
        SERVO.Set(ServoPen,Up)    ' 2400: max        600:min
    PUB Pen_Down
        SERVO.Set(ServoPen,Down)    ' 2400: max        600:min
    I'm trying to draw this square with no continues sides using my S2 but the pen stays down...
    On the other hand, the following code can lift up and down the pen without problem:
    OBJ
      SERVO : "Servo32v7.spin"
    CON
        ServoCh1 = 5               ' Servo to pin 0 - 5
    PUB Servo32_DEMO
      repeat
        ' Syntax: SERVO.Set(Pin, Width)
        SERVO.Set(ServoCh1,2080)    ' 2400: max       Pen Up
         repeat 800000               ' Wait a short bit
        SERVO.Set(ServoCh1,1600)    ' 1500 usec (centered)  600:min   Pen Down
          repeat 800000
    I use a Hitec Hs 55 servo connected on Pin P5 on hacker Port and the following motor characteristic
    So the question is how can I make the S2 manipulate the Pen-servo while it moves using the S2 object commands?
    What goes wrong with the first code?
    Phil can you Help Please?
    320 x 269 - 4K
    You are missing Servo.start in the first program.
    edit: I see you have multiple Servo.starts. you only need to call it once at the beginning of your program.
    Nikos,
    Try it without the begin_path and end_path commands, then call wait_stop before issuing a pen-up or pen-down. The reason for this is that drawing commands are semi-buffered to be executed in the background. A pen-up/draw-command/pen-down sequence is likely to be executed in rapid sequence before the draw command even has a chance to get started.
    Pich,
    Nothing again.....
    The servo makes only a small reaction in the first command (Pen_Down) end then nothing. It is like doesn't exist....
    Hi Phil,
    I wrote the following:
    CON
       Up    = 1200' 2080
       Down  = 1600
        ServoPen  = 5
    OBJ
    s2 : "S2"
    PUB Main
     S2.start
     s2.wait_stop
       S2.start_motors
       S2.set_speed(7)
       S2.here_is(0,0)
       S2.move_to(300,0)
     s2.wait_stop
       Pen_Up
       S2.move_to(600,0)
     s2.wait_stop
       Pen_Down
       S2.move_to(900,0)
       S2.move_to(900,300)
     s2.wait_stop
        Pen_Up
       S2.move_to(900,600)
     s2.wait_stop
        Pen_Down
       S2.move_to(900,900)
       S2.move_to(600,900)
     s2.wait_stop
       Pen_Up
       S2.move_to(300,900)
     s2.wait_stop
        Pen_Down
       S2.move_to(0,900)
       S2.move_to(0,600)
    s2.wait_stop
     Pen_Up
       S2.move_to(0,300)
    s2.wait_stop
      Pen_Down
       S2.move_to(0,0)
    PUB    Pen_up
    PUB Pen_Down
    Unfortunatelly the problem remains.
    Hmm. I wonder if the wait_stop is getting executed before motion even begins. Try inserting this before each wait_stop:
    repeat until s2.moving
