Binary Clock
I'm trying to build a binary clock. Hour Minutes and Seconds I have a DS1307 connected to the Propeller. There are 4 LEDs connected to pins 0-3 for the hours. 8,4,2,1 Then 6 LEDs connected to pins 4-9 for the minutes. 32,16,8,4,2,1 There are 6 LEDs connected to pins 10-15 for seconds. 32,16,8,4,2,1 How do I convert the decimal DS1307 to binary output to the LEDs?
  • 8 Comments sorted by Votes Date Added
  • edited October 2010 Posts: 0Vote Up0Vote Down
    The standard technique for converting from one base to another is to keep dividing the number by the new base, outputting the remainders in reverse order. Try doing it with pencil and paper.
    Leon Heller<br>G1HSM
    The output is BCD which is really easy to convert -- here's a method you could use:
    pub frombcd(bcdval)
      return ((bcdval >> 4) * 10) + (bcdval & $F)
    <br>
    So the RTC (real time clock) sends BCD (binary-coded decimal) to make it easy to display the digits on normal 2digit pairs 7seg.
    You want to scramble it back to raw binary.
    If the minutes is at 49, in BCD you would get %0100_1001
    ' in this example bcd = 49 = %0100_1001
    dat
    mov temp, bcd        ' bcd= two 4 bit nybbles
    and bcd, #%1111      ' just keep the lower nybble = 9
    and temp, #%11110000 ' just keep the higer nybble = 64
    shr temp, #1         ' divide by 2 = 32
    add bcd, temp        ' add it to new bcd. 32+9 = 41
    shr temp, #2         ' divide it by 4  = 8
    add bcd, temp        ' add it to bcd, the bcd is now 49
     ...                 ' continue your regular code here.
    bcd long %01001001
    temp res 1
    If you are doing a binary readout clock why not go all the way and use only 10 leds (11 if you want a 24 hour clock).
    In science there is no authority. There is only experiment.
  • edited October 2010 Posts: 203Vote Up0Vote Down
    This is How my display looks for clarity. The O are LEDs
    O O O O O O O O O O O O O O O O
    32 16 8 4 2 1 32 16 8 4 2 1 8 4 2 1
    Hours Minutes Seconds
    Im not doing the BCD
    8 O O O
    4 O O O O O
    2 O O O O O
    1 O O O O O O
    H M S
    Attached is my code it only has seconds works great but the code is very long.
    if sec == 0
    outa[10..15] := %000000
    I hope you did see a pattern and that all your code so far can be replaced
    with a single line of
    outa[10..15] := sec
    and that the rtcEngine already have NumBCD<>BCDNum converter built-in
    Thanks a lot Tonyp12 that worked great.
