How to send 4-20mA (1/3000 resolution)
BronsonBronson Posts: 44
edited August 2010 in BASIC Stamp Vote Up0Vote Down
I am doing a project using BS2 that need to send 4-20mA signal (1/3000 resolution).
The workflow is: After BS2 receiving input through RS-232 (ASCII), it will send 4-20mA signal.
I have no problem receiving ASCII data through RS232 and process the ASCII with BS2, but I have zero-knowledge about sending 4-20mA using BS2.
By browsing this forum, I found that I need DAC (16-bit for 1/3000 resolution). Can I use MAX5661? How to do the wiring between MAX5661 (or any 16-bit DAC) and BS2? How to do the BS2 code?
Pls help me.....Thx a lot
Bronson Alex
  • 8 Comments sorted by Date Added Votes
  • BronsonBronson Posts: 44
    edited August 2010 Vote Up0Vote Down
    Is AD421 (DAC 12-bit Serial-interface) suitable for BS2?
    Here's a recent Subject that dealt with 4-20mA:
    http://forums.parallax.com/showthread.php?t=120302&highlight=20mA
    Unfortunately, the ascii-art didn't exactly translate with the Forum's migration to its present format (if you copy and paste it into Notepad, it'll probably come right, with Lucida Console.) When it comes to pics I always post Dwgs, text is for text.
    For the DAC'ing, go to the Parallax http://www.parallax.com store site and search for DAC. You'll find links to sample programs, etc., which should provide clues for you if not for your specific device.
    Attached is a dwg for a current source (regulator.)
    It's not ascii-art, but it'll have to do.
    377 x 317 - 51K
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,583
    The AD421 should work fine with the BS2. Since it's a loop-powered transmitter, you could even use it with digital isolators between it and the Stamp.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
    Phil, Could you pls send me the wiring diagram for using AD421?
    Thx
    I don't have a wiring diagram. The AD421 datasheet includes the information you need. Aslo, there's a schematic on this page that shows the AD421 connected to a PIC. The connection would be similar for a BASIC Stamp.
    Thanks Phil...
    I will try your suiggestion right away.
