Servo control continuous run — Parallax Forums
kuragikuragi Posts: 1
edited 2010-08-18 16:43 in General Discussion
I was wondering if it was possible to have a servo continuously run from a update command.
I have
left_Servo.update(220,2304);
right_Servo.update(126,2304);
and I want them to run without a CPU.delay() command until I tell them to stop. Is there anyway to do this?
*UPDATE*
Sorry about this guys, I figured it out, somewhere way farther down in my code I had a identical method that was stopping the servos. Must have been up too late programming.
  • jmspaggijmspaggi Posts: 629
    Hi kuragi,
    Just in case someone have the same issue, can you just post want you found in the forum?
    JM
