Parallax Propeller Programs Propellers in ParallelV1.0- Tribute to the BigBoy 4
Clock LoopClock Loop Posts: 1,310
edited December 2010 in Propeller 1 Vote Up0Vote Down
The bottom post has V1.0 Schematic and Program.
I made a program and schematic that shows a single propeller that can program 2 or more propeller chips at the same time on the same RX, TX, RESET, CLOCK lines.
I structured it around the Locomotive "BigBoy" because the parallel programming makes some redundancy possible.
The propeller loader can be used to program propeller chips in parallel.
I do not know the accuracy of how "parallel" the internal programs are really running, but because all props run from a single clock,
the difference if present, could be calculated and accounted for.
***using the TX line as a way to sync all slave props, near perfect program alignment is achieved***
TERMS OF USE: MIT License
"Permission is hereby granted, free of charge, to any pers...........................
..............................OMITTED FOR FORUM...............................................
.................. OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. "
The dsp/fpga king is dead, long live the prop.
Post Edited (Clock Loop) : 8/5/2010 8:41:09 AM GMT
To study the nature of randomness in a digital processor network using the same clock source, 54 prop chips were all connected to a master prop. http://forums.parallax.com/discussion/127983/55-parallax-propeller-s-parallells-processing-of-permanent-perturbations/p1
Optic communication between homogenous and commensurable, 8-core, 635nm emitting, phase locked loop, bit salad tossing units? http://forums.parallax.com/discussion/comment/1248240/#Comment_1248240
TheBlackBox: Release v2.0 - Propeller HSS FX/Sequencer with Digital Audio SPDIF output. http://forums.parallax.com/discussion/115258/theblackbox-release-v2-0-propeller-hss-fx-sequencer-with-digital-audio-spdif
E-Tools - Mono555 calculator, resistor calculator, voltage divider calculator, RCtime calculator, LM317 calculator, Binary-Hex-Decimal calculator, Resistor color matrix, Series LED resistance calculator, OHMS LAW calculator.
http://forums.parallax.com/discussion/81449/e-tools-html-java-script-electronic-design-tools-free-for-you
2
