Subroutine call inside an ISR — Parallax Forums
SelfPropelledSelfPropelled Posts: 6
edited 2010-06-29 22:47 in General Discussion
It appears that calling a Subroutine from an Interrupt causes problems.
The SUB directive occurs after the ISR routine, so the Sub call generates
an 'unkown command' error.
Moving the SUB directive above the ISR routine causes other problems.
Am I missing something?
[noparse][[/noparse]code]
' INTERRUPT
ISR_Start:
PULSOUT RA.0, 1000 'FLASH TEST LED
PULSOUT RA.1, 1000
PULSOUT RA.2, 1000
READKEY ' <<< THIS GENERATES COMPILER ERROR 'UNKNOWN COMMAND'
ISR_Exit:
Keys = %0000_0000 'Set Key Row Drive low for WKED
WakePend = %0000_0000 'CLEAR INTERRUPT PENDING FLAG.
RETURNINT
PROGRAM Start
' Program Code
READKEY SUB 0 ' <<< Is this in the right place?
Start:
TRIS_Keys = %1111_0000 ' refresh IO state
Keys = %0000_0000 ' Set Key Row Drive low for WKED
WKED_B = %1111_1111 ' Falling edge detect
WKEN_B = %0000_1111 ' Use bits 4-7 for inputs
ST_B = %0000_1111 ' Bits 4-7 are Schmitt Trigger Inputs
SUB READKEY
ENDSUB
  • BeanBean Posts: 8,129
    edited 2010-06-29 21:01
    You need to use GOTO
    ' INTERRUPT
    ISR_Start:
      GOTO ISR_Code
    PROGRAM Start
    ' Program Code
    Start:
    ISR_Code:
    PULSOUT RA.1, 1000
    PULSOUT RA.2, 1000
    ISR_Exit:
    RETURNINT
    SUB READKEY
    ENDSUB
    Bean
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
    There are two rules in life:
    · 1) Never divulge all information
    If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
  • JonnyMacJonnyMac Posts: 8,912
    edited 2010-06-29 21:04
    To do this you have to move the ISR code below the SUB/FUNC definitions. The easiest way to do this is to add:
    GOTO ISR_Handler
    In the interrupt section -- this is the only thing there. Somewhere in your listing (usually after the main body of the program) you'll have this:
    ISR_Handler:
      ' your code here
      RETURNINT
    Jon McPhalen
    Hollywood, CA
  • SelfPropelledSelfPropelled Posts: 6
    edited 2010-06-29 21:08
    TY Bean.
    Much appreciated.
    JonnyMac,
    I missed your reply earlier.
    Nice approach.
    Thanks very much.
