Has anyone used their propscope as a signal generator?
turbosupraturbosupra Posts: 1,088
edited May 2010 in Accessories Vote Up0Vote Down
I was considering getting a signal generator off of ebay (not sure which model would be best to get yet, but I would like to be able to go from 50hz to 500,000hz and from 0 to 15vDC) and I just realized that the prop scope has the ability to be a signal generator.
Do I need expansion hardware or can I do this within the software and just use the second set of probes? What are the capabilities of the prop scope signal generator? If anyone has used it, how well does it work?
Thanks!
  • 8 Comments sorted by Date Added Votes
  • HannoHanno Posts: 1,130
    edited May 2010 Vote Up0Vote Down
    Do I count?
    Yes, the PropScope's function generator should be very capable. You can output arbitrary waveforms (with easy presets for sine, square, sawtooth) at frequencies from .1Hz to 5MHz in .1Hz increments. You can adjust amplitude/offset to fit in either -1.5V..1.5V or 0..5V ranges. You can draw custom waveforms with your mouse or import from files.
    I made some improvements in the v1.05beta floating on one of these threads- use that for best results...
    Hanno
    Co-author of the official Propeller Guide- available at Amazon
    Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
    12Blocks, the block-based programming environment (thread here)
    and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
    Professional IDE to edit, debug, and run SPIN, PropBasic and C: ViewPort
    Visual programming language: 12Blocks
    Multi-function Oscilloscope/LSA/Function Generator: PropScope
    500 page book of Propeller Projects:Programming and Customizing the Multicore Propeller
    Blog:http://onerobot.org/blog
  • turbosupraturbosupra Posts: 1,088
    Haha, you definitely count Hanno!
    Do I have to buy additional hardware to use my prop scope as a sig gen?
    Is there a way to go 0 to 15v with it? Maybe with an external power supply?
    Hanno said...
    Do I count?
    Hanno
  • hover1hover1 Posts: 1,927
    Turbo,
    The Signal Generation occurs on the DAC Card. The BNC connector closest to the PropScope is the output. See page 6: http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32220GettingStartedv1.0.pdf
    5 volts is all you are going to get out of the DAC board. It is being powered by the USB cable, (USB= 5 volts). You could amplify the 5 volt signal later to get the voltage you need.
    Jim
    turbosupra said...
    Hanno said...
    Do I count?
    Hanno
    I have three propellers
    Sorry I forgot to address your hardware question- as usual, Hover1 is right- you only need to plug the included expansion card into your PropScope and connect signals to the inner BNC... These forums are wonderful!
    Now, how about a new challenge to solve TS's problem:
    Design a simple circuit that:
    - scales the PropScope's analog output to a higher voltage range- for example, 0-5V becomes 0-15V
    - supports frequencies between .1 and 5MHz without introducing artifacts
    - uses as few commonly DIP parts as possible
    Hanno
    Hi Hanno!
    I don't remember ever seeing my expansion card? I'm guessing I received one though and it is in the box, I'll have to check.
    So about this circuit, how would it work? And is 5mhz the highest the pscope will go?
    Let me know if you've designed and built one of these, I'll buy it
    Hanno said...
    Hanno
  • edited May 2010 Vote Up0Vote Down
    - 10 to + 10 V amplitude range would be very nice for a general purpose signal gen.
  • BradCBradC Posts: 2,601
    TonyF (spinvent.co.uk) said...
    So design a DAC board with a couple of small boost converters on it to give you the right rails and go for it.
    "Are you suggesting coconuts migrate?"
    wtf?
