SASM — Parallax Forums
SASM
edgellmhedgellmh Posts: 85
edited 2010-05-21 18:27 in General Discussion
I can't find the source code generated by my SX/B code. There is no SASM Output file on my computer.
marshall
  • JonnyMacJonnyMac Posts: 8,924
    edited 2010-05-17 02:33
    Press [noparse][[/noparse]Ctrl]-[noparse][[/noparse]L] to see it on screen
    Jon McPhalen
    Hollywood, CA
  • edgellmhedgellmh Posts: 85
    edited 2010-05-20 14:49
    I want to send someone the assembly listing but the CNTRL-L listing can't be copied.
    marshall
  • skynuggetskynugget Posts: 172
    edited 2010-05-20 16:28
    if you pull up the Ctrl-L list file, then highlight what you want with the mouse, and right click, you will see "copy" in the menu. Ctrl-C for copy doesn't work. you can also right click anywhere in the list file, and you will be able to "select all" if you are so inclined.
    Thanks. That did the trick.
    marshall
