Locating & Identifying propeller chip via USB — Parallax Forums
MacTuxLinMacTuxLin Posts: 821
edited 2012-02-01 22:24 in Propeller 1
Hello All,
I'm rather new here & hope some kind soul could direct me to a link or note to read up on how an app (Java or any desktop app) could locate, identify & connect to a propeller-chip board if it is connected via the USB. I'll be using SPIN on the propeller and I think I'll need to allocate Pin 30 & 31 for polling but how do I use, say Javax.comm, to connect to propeller?
Thanks in advance.
  • RaymanRayman Posts: 13,855
    edited 2010-04-07 10:08
    I think the Propellant library can do that... I believe there's a dll interface for it.
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
  • MacTuxLinMacTuxLin Posts: 821
    edited 2010-04-07 10:15
    Rayman, thank you. Just downloaded the Propellent.
  • obrienmobrienm Posts: 65
    edited 2012-02-01 19:26
    The standard javax.comm library originally developed for linux but extended for win32 works fine for me, no resets. The library will not work on a 64 bit JVM but I am able to control multiple quickstart boards simultaneously from a single java process after first reloading them all using propellent in an Ant script.
    see http://javahardware.blogspot.com/2010/11/led-display-board-driven-by-javaxcomm.html
    and the original posts
    http://forums.parallax.com/showthread.php?119851-Writting-propeller-data-to-a-file-on-my-PC&p=879906&viewfull=1#post879906
    http://forums.parallax.com/showthread.php?109333-HowTo-Single-host-computer-and-multiple-propeller-serial-comm-and-programming&p=775612&viewfull=1#post775612
    http://forums.parallax.com/showthread.php?137636-Quickstart-Board-reboots-when-PC-GUI-program-starts-and-stops&p=1071154&viewfull=1#post1071154
    http://forums.parallax.com/showthread.php?132944-Java-comm-and-basic-stamp
    Ant picks up extra verbosity from propellent
    <project name="grid" default="reload.all">
    <property name="spin.file" value="lcas_20120129_grid_f_input.spin"/>
    <property name="EEPROM" value="/EEPROM"/>
    <!--property name="EEPROM" value=""/-->
    <target name="reload.all" description="reload entire grid">
    	<antcall target="reload">		<param name="port" value="23"/>	</antcall>
    	<antcall target="reload">		<param name="port" value="48"/>	</antcall>
    	<antcall target="reload">  		<param name="port" value="47"/>	</antcall>
    	<antcall target="reload">		<param name="port" value="46"/>	</antcall>
    </target>
    <target name="reload">
      <apply executable="propellent">
    	<arg value="/PORT"/>
    	<arg value="comm${port}"/>
    	<arg value="${EEPROM}"/>
    	<fileset dir=".">
    		<patternset>
    			<include name="${spin.file}"/>
    		</patternset>
    	</fileset>
      </apply>
    </target>
    </project>
    propellent output
    G:\_dev\active\_parallax\20111211_lcas_qs>ant
    Buildfile: build.xml
    reload.all:
    reload:
        [apply] &#9786;EVT:501-Compiling: FULLDUPLEXSERIAL
        [apply] &#9786;EVT:501-Compiling: LCAS_20120129_GRID_F_INPUT
        [apply] &#9786;EVT:502-File(s) compiled successfully.
        [apply] &#9786;EVT:503-Checking COM23
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM23.
        [apply] &#9786;EVT:506-Loading RAM
        [apply] &#9786;EVT:507-Verifying RAM
        [apply] &#9786;EVT:508-Programming EEPROM
        [apply] &#9786;EVT:509-Verifying EEPROM
        [apply] &#9786;INF:451-Success.
        [apply] &#9830;
    reload:
        [apply] &#9786;EVT:503-Checking COM48
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM48.
        [apply] &#9830;
    reload:
        [apply] &#9786;EVT:503-Checking COM47
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM47.
        [apply] &#9830;
    reload:
        [apply] &#9786;EVT:503-Checking COM46
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM46.
        [apply] &#9830;
    BUILD SUCCESSFUL
    Total time: 22 seconds
    thank you
    /michael
    @Michael,
    This is cool! Its funny, when you needed something its always hard to find but they seems to jump right in front of you when you don't. -_-" .... I've actually detoured to VB.net since then but guess its time to re-look at it again (maybe in June).
