Can Parallax do something about the FTDI reset bug?
KyeKye Posts: 2,200
edited February 2013 in Propeller 1 Vote Up0Vote Down
So, I just finished up a robotic project for a fellow classmate, and when I took the programing cable out and started to run the device by itself it kept reseting over and over again.
I managed to fix it by disabling all the code involving serial data transfer. However, I would rather of not had to do that.
Now I know this issue has been brought up before. But can Parallax do an official review of the problem and publish a paper or something on how to avoid it?
I know the problem is not the propeller chip's fault but its not to my advantage or anyone else's advantage that this bug is only known about and the fix is·buried deep within these forums. Maybe at least there should be an official sticky on this so that everyone knows.
Thank you,
Nyamekye,
Nyamekye,
«13
  • 82 Comments sorted by Date Added Votes
  • Peter JakackiPeter Jakacki Posts: 6,695
    edited October 2009 Vote Up0Vote Down
    Kye, are you just talking about your software crashing because it is waiting to run commands from the programming port and the FTDI chip is bus powered and so pulls the rx line low when disconnected? Surely you just want break detection and rejection in your serial code (which BTW should be standard). Otherwise you may just need a pullup on the reset line if you have it running more than a very short distance.
    *Peter*
    Tachyon Forth - compact, fast, forthwright and interactive
    Tachyon Forth News Blog
    TACHYON DEMONSTRATOR
    Brisbane, Australia
  • RaymanRayman Posts: 8,362
    I've found (at least I'm pretty sure) that putting series 1k resistors on the RX and TX lines·avoids the problem...
    Prop Info and Apps: http://www.rayslogic.com/
  • Bob Lawrence (VE1RLL)Bob Lawrence (VE1RLL) Posts: 1,451
    Phil said...
    This is a known problem with the USB circuitry when it's not plugged into a USB port. Put a 2.2K pullup from A30 to Vdd, and the problem should go away. Here's a link that explains why:
    forums.parallax.com/forums/default.aspx?f=25&m=192068
    The pullup isn't the best solution, since it's actually being used to power the FTDI chip. nono A better solution would be buffer circuitry between the FTDI chip and the Prop, so current doesn't backfeed through the FT232R's serial I/O pins.
    More Info:
    http://forums.parallax.com/showthread.php?p=651731
    Post Edited (Bob Lawrence (VE1RLL)) : 10/12/2009 12:28:43 AM GMT
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,410
    Here's another thread by yet another (I think) victim of this issue: http://forums.parallax.com/showthread.php?p=847305. In the face of so many complaints about this, spanning more than two years, it would be nice if Parallax would at least acknowledge that a problem exists. Although it's too late for a full solution to the problem where the Prop Plug is involved (the required open-drain buffer needs access to both Vdd and VccIO supplies), it's not too late to begin designing this buffer into boards that include both the Prop and FTDI chip.
    For Prop Plug users, of course, the solution is simpler: just unplug the USB cable and Prop Plug, instead of just the USB cable.
    Post Edited (Phil Pilgrim (PhiPi)) : 10/12/2009 1:25:08 AM GMT
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • Ken GraceyKen Gracey Posts: 6,089
    Hey guys,
    I've met Fred Dart from FTDI (one of the owners), having visited us before here in Rocklin in recent years. I'm aware of the problem, too, but may need a definitive explanation of the problem AND the solution before we start making requests.
    Phil, can you brief me on the FULL solution you mention above so I'm making the right request to Fred?
    Ken,
    Thanks for joining the discussion! Now I know we'll see some action! smile.gif
    The problem is this: When the USB cable is unplugged, a program that uses pin A30 for a serial output will assert that pin high after reset. This, in turn, will power the FTDI chip through its RXD input pin, which causes the DTR# output to rise, sending a reset back to the Prop. During reset, pin A30 tristates, and the FTDI chip loses power until the Prop comes out of reset again, starting the cycle all over. Putting a pullup on pin A30 "solves" the problem by keeping the FTDI chip powered during reset, thus preventing repeated edges on DTR#. But this is a poor solution, since it relies on the FTDI's internal protection diodes to keep it powered whenever the Prop is powered.
    A better solution is to isolate the FTDI chip from the Prop circuitry using an open-drain buffer like the 74LVC2G07. This chip (and the entire LVC logic family) is capable of isolating independent supplies so the chip cannot power circuitry on either side from the other side's supply or input voltages. 'Best of all it's cheap. (It's used on the MoBoStamp-pe, BTW, for this very application.)
    Here's a circuit (the "full solution") that can be used on a board that has both the FTDI chip and Prop:
    Here's a circuit for an improved Prop Plug. It's not a "full" solution, though, since any Prop board that uses it needs to have pin A31 pulled up to Vdd:
    Instead of the 74LVC2G07 on the Prop Plug, one could use a non-open-drain buffer (e.g. 74LVC2G34), which would solve the reset problem, but it would still allow a connected USB port to power the Prop through pin A31. It's better, as I pointed out above, just to unplug the Prop Plug when the USB connection isn't being used.
    But for boards with both FTDI chip and Prop, a 74LVC2G07 buffer, along with a couple pullups, is the way to go.
    BTW, this is not an FTDI problem, so I don't feel that they are responsible for providing a solution. Nor is it a Propeller issue, per se. It's just a more generic matter of how two independent circuits should be interfaced when only one is being powered.
    Post Edited (Phil Pilgrim (PhiPi)) : 10/12/2009 4:12:58 AM GMT
    I don't seem to have this reset problem but my circuits are a little bit different anyway. I like the little SOT style logic chips too but here is an easy retrofit solution that should work.
    *Peter*
    751 x 362 - 11K
    Brisbane, Australia
    Peter,
    That, too, would work; but you would need second set going in the other direction to keep a powered FTDI chip from trying to power the Prop, which is another issue. The SOT 74LVC logic family has the additional advantage of 5V-tolerant inputs when powered from 3.3V — not an issue with Prop circuits, certainly, but a motivation for using it on the MoBoStamp-pe. The '2G07 buffer I recommended costs less than 11 cents on a full reel.
    Well I do totally agree with you Phil on the use of a cheap and simple buffer chip for new designs and I might use it too. The diode solution is a quick fix for a "help me out now" situation.
    *Peter*
    Brisbane, Australia
  • Cluso99Cluso99 Posts: 13,041
    I have not thought much about the problem, not having experienced it.
    However, on my TriBlade I have the circuit which includes the 2 x 150R t/hole series resistors. I suspect this is typical of many/most t/hole designs.
    I presume the power is being supplied to the FTDI and therefore only via the SO (P30) pin of the prop. Surely, it is not the power being supplied to the prop as that is already powered???
    If this is so, firstly, we only need to worry about the SO P30 pin. Most likely a high value resistor in this line would work. Alternately, a diode in place of the 150R series resistor, cathode to P30, and a pullup on the FTDI RX pin would work - that is, we make P30 an open drain style output but without the requirement for a software modification. Either of these would most likely be the easiest and simplest circuit modification.
    I will draw a circuit and add to this post shortly.
    Phil: I think the same problem will exist with the '07 buffer -(it is open drain)
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
    Post Edited (Cluso99) : 10/12/2009 4:02:56 AM GMT
    My Prop boards: P8XBlade2, RamBlade, CpuBlade, TriBlade
    Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
    Website: www.clusos.com
    Prop Tools (Index) , Emulators (Index) , ZiCog (Z80)
    Cluso99 said...
    It doesn't. I've used it (in the MoBoStamp-pe), and it works as advertised. The key is to use the 74LVC family, which lacks input protection diodes. Check out the datasheet; you'll see what I mean.
    Here a tutorial that explains TI's 74LVC "ioff" circuitry.
    Post Edited (Phil Pilgrim (PhiPi)) : 10/12/2009 2:51:54 AM GMT
    You are correct Phil. I checked out the spec, but omitted to remove the statement.
    Obviously my post crossed Peter's etc. But we have the same thoughts.
    Anyway, here is my recommended circuit. The resistor is the simplest and will most likely work. A diode·(1N914 or 1N4148) and pullup resistor (10K) would be second choice.
    BTW - I have not seen any problems with the reverse situation - powering the prop from the FT chip and this I do all the time as I don not disconnect the USB when depowering my TriBlade.
    Phil is probably correct - the shield of the USB should not be connected as this is the slave end, and only one end of a shield should be connected to avoid ground loops.
    Post Edited (Cluso99) : 10/12/2009 4:06:49 AM GMT
    931 x 483 - 86K
    A simple series resistor may not work, given that a pullup is enough to power the FTDI chip. Although the pullups that people have used to "solve" the problem are in the 1K - 2.2K range, a 4.7K resistor from the Prop pin may still provide enough current to cause trouble when A30 transitions high after reset. At the very least, I fear that it would flirt with the margins of reliability. Also, you would need the same protective circuitry going the other way on A31 to keep the FTDI chip from trying to power an unpowered Prop. (It probably wouldn't be successful, as you've observed, given the current requirements; but some have reported a faint glow from the Vdd LED in this situation, nonetheless. At the very least, the load on TXD could be excessive.) To me, at least, the LVC buffer seems the simpler and more robust solution. Plus, you gain an extra 0.6V of "low" voltage margin with a CMOS output compared to a blocking diode.
    A simple resistive load across the FTDI chip and one across the Prop will take care of those currents that find their way to the chip's supply effectively quashing the voltage. I would probably use a value of around 1K if power consumption is not an issue.
    *Peter*
    Brisbane, Australia
    Don't forget: VCCIO only has to rise a little above 0.6V to trigger the reset transistor.
    0.58V smile.gif (Oops, not quite. Forgot about Vfwd of the protection diode.)
    3.3V to 4K7 pullup through 0.3V substrate diode through 1K VCCIO to ground = 0.52V smile.gif
    But for new designs your idea Phil is a good way to go.
    *Peter*
    Brisbane, Australia
    Yes Peter, agreed.
    I am loathe to use a hard to get component and difficult to use for a hobbyist cure. They are plentiful from Digikey. For a complete smt pcb, such as Peter, others and myself use, this is not a problem. In fact I am using SOT23 and SM8/UM8 etc parts on RamBlade which includes the LCV1G & 2G parts.
  • KyeKye Posts: 2,200
    Thanks guys for the input. All I really care about is that when I buy a parallax demo board and disconnect it from the PC it should still continue to work without me having to comment out my serial driver code.
    Nyamekye,
    Nyamekye,
    Hey Kye, don't you know that threads can have a life of their own beyond the original intention!? smile.gif
    Sometimes it takes a simple question to get some matter out on the table for further discussion. Phil's little chip is cheap and small and so I may just use his idea for some circuits that might have problems. For 11 cents or whatever I'll put it in anyway.
    *Peter*
    Brisbane, Australia
  • DavidMDavidM Posts: 537
    I think you are talking about the same issue I spoke about some time ago, I have made a small PCB to solve this issue ( at least for me) , essentially its a prop plug with additional circuitry ( an analog switch) for the reset line. refer to schematic.
    This device works for me, I can plug & unplug the USB Cable without the PROP Resetting. ( once activated)
    I can send data via serial/usb to a MAC or PC
    I can program the PROP as normal.
    The only catch is you need another I/O pin to ENABLE /DISABLE programming ( i.e resetting)
    By default my PCB acts as a normal prop plug, to take advantage of the new feature you need to set the I/O pin to disable programming via CODE.
    So if you wish to re-program you need something in your prop device/app ( menu selection,button ect) to allow the user to ENABLE/DISABLE PROGRAMMING.
    I have use a IP67/68 rated USB Connector for panel mounting and a micro-match connector for attaching to the main PROP Board.
    As I said. This works for me.
    regards
    Dave M
    1588 x 1316 - 187K
    1428 x 1082 - 131K
    1858 x 1310 - 239K
    So does anyone have any comments about my USB PCB or schematic? Excuse the upside-down pics
    As I said it solve the re-setting issue for me.
    Dave M
  • BitsBits Posts: 414
    edited April 2012 Vote Up0Vote Down
    Phil, others
    Would another 74LVC2G07 need to be used when implementing the "rts" and "cts" pins on the FTDI ic?
    [h=2]I would love to change the world, but they won't give me the source code![/h]
    That would be my recommendation, yes.
  • pedwardpedward Posts: 1,466
    Hey Phil, what about putting a schottky diode between VCCIO and VCC of the FT232? In most circuits the VCCIO is connected to 3v3, which powers the Prop. If you put a feedback diode from VCCIO to VCC, VCC will get power off VCCIO and power the chip from 3v3.
    No, that's not the usual case. In most circuits, VCCIO is derived from the FT232R's internal 3.3V regulator and is used to power only the FT232R's I/O circuitry.
    Well, that's true for the Proto and Quickstart, however I chose to use the internal regulator in the FT232RL to power the PropKey (it's rated for 50ma), we'll see how it works. This is something that *can* change in most systems to power the FT232 from 3v3 if no USB power is present. According to the datasheet this is totally fine for the FT232.
  • Dave HeinDave Hein Posts: 5,309
    So a program that is intended to run on any Prop board should avoid starting a serial port on pins 31 & 30 if it's not connected to a computer, correct? Otherwise, it will continually reboot on some boards. Is there a list of boards that have this "feature"?
    I know the quickstart DOES NOT have this mis-feature.
  • jazzedjazzed Posts: 11,803
    pedward wrote: »
    True. It has that other mis-feature.
