Force new topics to have a subject line
PJMontyPJMonty Posts: 983
To help the willfully clueless who seem unable to grasp the concept of a subject line, how about having the forum refuse to accept a new forum topic unless it has a subject line? This will prevent moderators from having to tell people to "use the pencil icon", which only further confuses the already confused.
PeterM
  • 6 Comments sorted by Date Added Votes
    edited October 2009 Vote Up0Vote Down
    Peter,
    That has been a wish for a long time. The current software does not support this feature, however we are looking into this. Take care.
    Parallax Engineering
    Chris Savage | Engineering Tech | Main Office: (916) 624-8333 | Direct to Tech Support: (888) 997-8267 | Website | Twitter | Google+
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,583
    Peter,
    This has been suggested. I even mentioned once that, if it couldn't be forced, the default subject line should be changed from, "(No subject)" to, "The poster didn't care enough to include a subject, so this thread is probably not worth reading," or somesuch. But the problem, as I understand it, is that the forum software is a bit brittle and that making any small change would be like pulling a loose thread on a sweater.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • SRLMSRLM Posts: 5,044
    Personally, if a subject line couldn't be forced, then I would like a variable subject line where no subject was there for a day or so, then it switched to something like Phil said. Usually when I forget a subject (most often in email) it's because I am concentrating on the body so much that I forget the subject.
    2c
  • MoskogMoskog Posts: 524
    If I see a post with the No Subject, I always open that post because I'm getting very curious on what that new thread contains...
    KjellO
    LA3USA
  • Jim EwaldJim Ewald Posts: 656
    We found a way to locate the wayward threads. Josh is correcting all of the threads that have missing subjects. That doesn't fix the problem but it masks the symptoms quite well.
    Jim
    Parallax IT Dept.
