Process Control - Chapter 5 — Parallax Forums
MichelBMichelB Posts: 154
edited 2009-06-16 11:39 in Accessories
Hi, must I modify R6 in chapter 5 as indicated in errata for chapter 4 (Opto-Reflective...)?
  • dandreaedandreae Posts: 1,375
    edited 2009-06-15 14:13
    What version of the text are you using and what pages are you referring to?· I'll look into this and see what the correct values should be.
    Kind regards,
    Dave
    Dave Andreae
    Parallax Tech Support·
  • MichelBMichelB Posts: 154
    PC Parts & Text Kit #28176 (2006) same text as PCv1.0.pdf + PCErratav1.0.pdf. Errata concern only Chapter 4 but in Chapter 5, page 137, I suppose that R6 must be modified, 1 kohm instead of 100 ohm. Even with modifications indicated in errata none of opto-reflective activities ran, even with a new ADC0831 from an other kit. I suppose a problem with Opto-Reflective Switch. Best regards. MichelB
    P.S. Now I'm learning Chapter 6.
