No data from gps — Parallax Forums
No data from gps
BuddieBuddie Posts: 29
edited 2009-04-04 19:04 in Accessories
Hello,
I have a parallax GPS unit. Recently, I used it in a project and it worked fine. However, now I cannot get any serial signal from it. I have even reverted back to the trial program with no results and tried both floating /RAW and pulling it low. The light on the gps flashes and it gets a fix, but outputs no data.
Any help would be greatly appreciated!
    edited 2009-04-04 15:57
    I'd start by calling tech support on Monday.
    - Stephen
  • Craig EidCraig Eid Posts: 106
    edited 2009-04-04 17:10
    Buddie – Have you made any changes to your circuit? Since the GPS module requires a fair amount of current you may have a power problem. How are you powering the board? Which board are you using?·
    ························ Craig Eid
    ··········· Triad Research and Development
    Electical Engineering Design and Consulting Services
    ··················· www.TriadRD.com
  • BuddieBuddie Posts: 29
    edited 2009-04-04 17:15
    I removed the gps from my circuit and put it on a BOE to test. It is powered by a 2 amp wall adapter.
    Buddie,
    The 5 volt power supply (VDD) on the BOE is derived·from an LM2940, conservatively rated at 1 Amp. If you are powering the GPS module from VDD on the BOE and the remainder of your circuit functions properly, you can deduce that the power supply is not your problem.
