checking two input pin states in assembly — Parallax Forums
ionymousionymous Posts: 29
edited 2008-11-10 23:23 in Propeller 1
I am coding in assembly.
I have two input pins I am interested in, lets say pin 5 and 6.
The other inputs are in unknown states... I have not tied them to ground, and many are for peripherals since I'm using a development board.
I'm using "and" to mask the inputs I care about, and then "xor" with "wz" to determine if the bits I care about are set.
Here's an example:
                        mov     temp1, ina              'Get the current inputs
                        and     temp1, bothInputs       'Mask the inputs I care about
                        xor     temp1, bothInputs wz,nr 'Check if both inputs are high
        if_z            jmp     #BothInputsAreHigh
                        xor     temp1, justInput5 wz,nr 'Check if just input 5 is high
        if_z            jmp     #JustInput5IsHigh
bothInputs long %110_0000
justInput5 long %010_0000
temp1 long 0
Is this a good way to do it, or is there a better way?
Ion
  • AribaAriba Posts: 2,682
    You can use TEST, this is the same as AND with NR:
                     test    bothInputs,ina    wz,wc   'Mask the inputs I care about
      if_z           jmp     #BothInputsAreLow
      if_nz_and_nc   jmp     #BothInputsAreHigh        'Carry is cleared if an even number of bits is set
      if_nz_and_c    jmp     #OneInputsIsHigh          'Carry is set if an odd number of bits is set
                     test    justInput5,ina    wz      'Check if just input 5 is high
      if_nz          jmp     #JustInput5IsHigh
      if_z           jmp     #Input5IsLow
    ' for waiting until inputs are set:
                     waitpeq bothInputs,bothInputs     'Wait until both are set
                     waitpne bothInputs,bothInputs     'Wait until one or both are cleared
    The test for both inputs by the Carry works only with 2 inputs, if you have more bits, then your methode with xor is the right one.
    And be aware that:
    test maskreg,ina is not the same as test ina,maskreg
    the second does not work as expected, because the INA has to be the source register.
    Andy
