12 Bit A/D converter
j.m.krellj.m.krell Posts: 14
edited March 2008 in BASIC Stamp Vote Up0Vote Down
I'm trying to operate the 12 bit A/D converter that can be purchased via Parallax.· I have the program that is provided via the link and am wondering if it is possible to read only 1 of the two channels and use the result in an IF....THEN situatiion to signal an I/O pin to sound an alarm.· Also, if this is possible, I am wondering how this is so.··Attached is the program that is found on the link and what I've used.· Thank you very much as I greatly appreciate any help and have a great safe day!
  • 5 Comments sorted by Date Added Votes
  • J^3J^3 Posts: 121
    edited March 2008 Vote Up0Vote Down
    Hello J.M.
    I am currently using the same ADC for a project.· You can select just ch0 or ch1 on your ADC.· Take the | statement out of your code that ORs config.· Then you can make the 3rd bit of config a constant for channel 0 or 1.· Hope that helps.
  • sam_sam_samsam_sam_sam Posts: 2,144
    JJ
    Can you post the link where you got that code from
    Many Thanks if you could do this
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Sam
    _________________________>
    Now wanting to learn Spin Thanks for any idea that you may have and all of your time finding them
  • j.m.krellj.m.krell Posts: 14
    http://www.parallax.com/Portals/0/Downloads/docs/prod/appkit/ltc1298.pdf
    The code can be found on pages 7 & 8.
    Thank you!
    j.m.krell
    Thanks for the link to these pages
    Sam
    Sam
